Thread: heavy/weighty 1.9 wheels
Old 01-20-2014, 06:54 PM   #1
Default heavy/weighty 1.9 wheels
so,what's the heaviest 1.9 wheel out on the market?
from a wheel weight standpoint (heavier the better) is it best to go with a steel wheel like rc4wd or plastic with the steel rings?
i know lots of guys run lead weight or bbs...i don't like the bb idea,but may go for the lead weight around a plastic wheel setup.
i currently run rc4wd steel wagon wheels,but they are a pain to mount tires on...they drive me nuts and i hate them,until the are complete anyways,lol
sawhead is offline   Reply With Quote
Old 01-21-2014, 08:57 AM   #2
Default Re: heavy/weighty 1.9 wheels
I really like Moto Worx Racing wheels. They are CNC'd billet Alu. They are pretty heavy and he leaves a nice flat surface to add weight to...if you want.
Motoworx Racing
ski29mike is offline   Reply With Quote
Old 01-21-2014, 09:45 AM   #3
Motoworx Racing
I have the Motoworx 1.9 Limited Edition 10 Hole, Raw on Raw. These things are beefy..
T I N Y is offline   Reply With Quote
Old 01-21-2014, 10:13 AM   #4
Scale Detail Engineering
and sexy!
johnnyh66 is offline   Reply With Quote
Old 01-21-2014, 05:24 PM   #5
nice but pricey...they look like they would be much easier to mount tires to
i wish they had the LE 8 spoke 2.2 in a 1.9
how do these mount? do they come with the hub-pin style and hex?
any other suggestions?
Old 01-21-2014, 05:54 PM   #6
Mayhem Engineering Wheels have a bit of heft to them.
I seem to think the wheel / rings and hubs were ~3oz each for the Monsters:
treys1 is offline   Reply With Quote
Old 01-21-2014, 06:18 PM   #7
Just hex.
Old 01-21-2014, 06:35 PM   #8
what about integy wheels?
Old 01-21-2014, 09:23 PM   #9
I use the Axial 8 hole bead locks...
along with their wheel weight retainer system, fully loaded.
(^ not cheap compared to 1:1 stick on (tape) wheel weights.)
But I do like their ease of use/reuse capability.
With Axial's wheel weight ring/retainer loaded to full weight capacity...
the individual tire/wheel weight comes to 8.48 oz. (240.3 grams) ea.
Generally my weighted wheels are used when slo mo rock crawling.
But I'll occasionally swap to unweighted tires/wheels when I want a faster pace, a more brisk run and/or a longer battery run time.
Less tire/wheel weight means less battery drain
IMO...
the tire/wheel weights offer a more to scale observation/behavior in the suspension's ride quality.
The tire's sidewalls bulge and flex more when weighted.
This sidewall behavior replicates tires that are aired down low.
"unsprung" weight is helpful... for keeping the rubber side down...
(^ weight below the supporting springs)
adding weight to the axle's housing helps even more ( * beef tubes )
"sprung" weight, on the other hand, is most every crawler's enemy.
and most attempt to minimize that when possible.
( ^ chassis weight supported by the springs )
TacoCrawler is offline   Reply With Quote
Old 01-23-2014, 04:11 PM   #10
anyone else?
Old 08-14-2019, 07:11 AM   #11
I used the stick on wheel weights for real tires, and I wrapped the inside of the wheel with weights.
Each tire is almost 1lb each, and it works great, I haven't had the problem of tolling it all the time.
Troy Wilkinson is offline   Reply With Quote
heavy/weighty 1.9 wheels - Similar Threads
Best scale 2.2 wheels & tires for a very heavy rig? fbuonpensiero Tires and Wheels 11 12-09-2011 10:07 AM
Light weight wheels vs traditional heavy on a Bully papabash RC4WD Bully 39 08-02-2010 01:17 AM
Wheels... Heavy or Light? why? the02stangman Tires and Wheels 8 10-26-2009 09:35 PM
New Erikson Heavy Beadlock Wheels Just Zach Tires and Wheels 13 05-14-2007 10:25 AM
