112mm Ti Links/SSD Diamond Front Axle Hi All, can anyone direct me to a source for quality 112mm Titanium links for a 13.3" (313mm) WB SX10? I'm using SSD links everywhere else except for the front uppers where I'm using an Integy link that isn't the correct size. I can't find 112mm SSD links anywhere. Would use Vanquish but don't think they have them either. Also, I'm using the SSD front Diamond axle. It appears that when the links are set to the proper length (112 eye to eye front top and 122 front bottom) the servo slants backward causing an awkward geometry for the steering linkage/servo arm. Is this correct or have I botched it up? Or, does the Diamond axle require different length links? Thanks for any direction or insight you all can give. Mike |
Re: 112mm Ti Links/SSD Diamond Front Axle The servo is slanted back slightly as the axle will be rotated forward slightly under the chassis. Diamond Front Axle for SCX10 (Grey) |
Re: 112mm Ti Links/SSD Diamond Front Axle Thanks for the reply. Do you guys make a Ti link that measures 112mm eye to eye? |
Re: 112mm Ti Links/SSD Diamond Front Axle Best Titanium links I've used! https://lunsfordracing.com/ |
