08-03-2020, 06:46 PM | #1 |
Pebble Pounder Join Date: Aug 2020
| New here
Just placed an order for a SCX10 ii figured I’d join a forum since I don’t have Facebook. I’m Austin from central/western Indiana. Had an emaxx years ago so I’m not a total newb. Still have my duratrax intellipeak and a pair of their 4200mah 6 cells from it I’m gonna try in this axial before I buy new. Sent from my iPhone using Tapatalk |
08-03-2020, 07:00 PM | #2 |
Quarry Creeper Join Date: Sep 2013 Location: Hicktown
| Re: New here
Welcome. Which SCX10.2? RTR? Kit? Got any plans in mind? The crawling is by far the most addictive for me. So many directions you can take a build. |
08-03-2020, 07:00 PM | #3 | |
Quarry Creeper Join Date: May 2010 Location: ny
| Re: New here Quote:
Sent from my SM-G965U using Tapatalk | |
08-03-2020, 07:08 PM | #4 | ||
| Re: New here Quote:
10.2 rtr. Hoping I can keep it off the work bench and out in woods. I’m the kinda person that can’t leave well enough alone so I’m sure I’ll find a way to dump money in it. Quote:
Why do you say that? I can swap later, it was just nice having those laying around to help with start up cost Sent from my iPhone using Tapatalk | ||
08-03-2020, 07:17 PM | #5 |
| Re: New here
Welcome Austin! A lot of people trash on the stock setup, and say anything but the latest and greatest is trash. I am one to see how far stock will go and then upgrade as needed. The 4200 nimh batteries will give you enough wheel speed and run time to make progress on a trail, but doesn't have the the energy density of a lipo pack. My old 4200 nimh's would get me about as far as my current 2200 lipo packs, just to give you an idea. I also run 3s or 12.4 volts in my stock Honcho without any ill effects. I do run small tires though. My advise for anyone new to crawling is to run your rig first, then decide on what you need to change. Btw, I would not be suprised if your nimh packs were dead. Trail Honcho, For Trailing |
08-03-2020, 07:18 PM | #6 |
| Re: New here
The difference with LiPo batteries is night and day. Really you can land a 5000mah 2s LiPo for around $25. Of course your charger needs to be able to charge LiPo so that may add into your initial cost. But once you make the switch you wont go back...not even to let your friends use...
08-03-2020, 07:19 PM | #7 | |
| Re: New here Quote:
08-03-2020, 09:07 PM | #8 | |||
| Re: New here Quote:
I didn’t take anything as trashing the rig. I’m the same way, I want to see what it can do and where it needs improvement before I buy anything. I’m sure I’ll enjoy it as is but I doubt it’ll stay stock Quote:
I’m sure I’ll get some eventually, just nice not having to buy them upfront. Well if mine aren’t dead... lol I do know I stored them charged, I put them on the charger last night and it only ran for like 15 minutes. Need to put a multimeter on them and see what voltage they’re holding. Sent from my iPhone using Tapatalk | |||
08-03-2020, 09:12 PM | #9 |
| Re: New here
Welcome to the site! Good choice for your first truck because it's very capable. The NiMH batteries are just old technology and don't have the power density of LiPo batteries. Just as a quick example, a 5000mAh NiMH battery will give you about 15 minutes run time out of a fast RC whereas a LiPo will give you about an hour. NiMH will work fine to start as long as you can still charge them. If you don't like the run times of the NiMH batteries, you can always upgrade to the LiPo batteries and charger. |
08-04-2020, 01:46 PM | #10 |
Rock Stacker Join Date: Sep 2009 Location: Westchester
| Re: New here
I'm in a similar boat. My son got excited seeing the old RC cars in the basement and wanted to get going with them. I picked up a few SCX24, so he'd have a RTR while I got the older SCX10 working again. I had NiMH batteries from 11 years ago when I last ran it and had hoped to reuse..... 11 years of non-use makes those batteries no go. LiPos are much better. They make the difference of NiMH vs NiCad look like nothing. Considering my first car was a Tamiya Frog when they first came out and had only a 3 position mechanical speed control with resistors and 72Mhz with discreet crystals per channel for the radio (radio impound/channel management was a must have back then), there has been a tremendous amount of progress over the years. While ESCs were around when I last did RC, the past 10 years has had huge improvements between brushless motors and LiPos. |
08-04-2020, 09:01 PM | #11 |
| Re: New here
Is there a general consensus on what batteries/charger everyone here prefers? Both those nimh of mine tested 8.5v a few hours after they came off the charger but I think I’m gonna go ahead with everyone’s recommendations here to get LiPo’s. Should get the truck tomorrow! Sent from my iPhone using Tapatalk |
08-10-2020, 08:11 PM | #12 | |
| Re: New here Quote:
I also have the Venom Duo pro... 2x packs charged at the same time on seperate channels, though it only charges up to 6 amps per. Last edited by lonleycreeper; 08-10-2020 at 08:30 PM. | |
