03-18-2021, 06:26 PM | #1 |
Rock Crawler Join Date: Jan 2007 Location: monson
| Resurrection of plain jane ax10 axles
Seeing all these awesome rigs spurred me to rebuild the ole girl. She started her life as a B-17 Betty and slowly transformed into a ram charger. Time for some new axles, but none of this new fangled scxii or iii. Dropping the ax10s Out with the old. All I'm keeping New axle and carrier housing built up. Original guts and knuckles I doubt these will take 3s, but that's ok, I run 2s and an out runner. Why am I running a carrier with caps, no good reason, cause I can. Also I'm sure someone will pick up on my biggest mistake, I'll have to do another housing. Sent from my SM-G955U using Tapatalk Last edited by 500swmag; 03-19-2021 at 09:11 AM. |
03-20-2021, 04:36 PM | #2 |
| Re: Resurrection of plain jane ax10 axles
So, I'm sure it was caught, I forgot the link mount for the upper link. Dumb. Well, used a piece from old axles and got them mounted up Sent from my SM-G955U using Tapatalk |
03-21-2021, 04:06 AM | #3 |
Quarry Creeper Join Date: Dec 2009 Location: Strafford, NH
Looks good.
03-21-2021, 10:25 AM | #4 |
Looks fantastic! love the look of your design.
03-21-2021, 06:22 PM | #5 |
Thanks guys. Took them out for a thrashing today, the rocks where I go are like razors Next is redoing the axle housing, with actual upper link mount this time. Then on to do the rear. Also making a standard 3 link setup for my son's truck, direct replacement. Sent from my SM-G955U using Tapatalk |
03-23-2021, 06:10 AM | #6 |
Quarry Creeper Join Date: Dec 2013 Location: The Garden State, North of I-80
Wow! You driving over 80 grit sandpaper???? |
03-24-2021, 10:29 AM | #7 |
yeah, it's brutal on under carriage. Links go away quickly. Conant Dam in Monson, MA |
03-24-2021, 07:18 PM | #8 |
Finished modeling the axle housing for my son's scx10, here's a teaser. Sent from my SM-G955U using Tapatalk |
03-26-2021, 07:31 AM | #9 |
looking for input from scx10 2 and 3, trx 4, redcat, basically any newer rc axle. what kingpin angle is standard for these toy axles, 5-8 degree? thanks in advance. -500 Last edited by 500swmag; 03-26-2021 at 08:04 AM. |
03-26-2021, 09:15 AM | #10 | |
i found some info. any other input is welcome. Quote:
03-31-2021, 06:24 PM | #11 |
The new housings with proper upper link mounts are still being fabed, but I found an old set of gmc eaton 2.5 ton axles at the military surplus yard on the way home. New inners and some cleanup and they'll go under my son's scx10. Sent from my SM-G955U using Tapatalk |
03-31-2021, 07:42 PM | #12 |
^^^ those are givin' me service-related flashbacks! |
04-01-2021, 09:16 AM | #13 |
| Re: Resurrection of plain jane ax10 axles |
04-05-2021, 08:07 PM | #14 |
New housings in, all guts transferred. 8 degree kingpins Limit stops Upper mount for 3rd link Stock lower link/shock mounts Double supported steering arms Panhard mount adjusted New tie rod needed, then On to the rear Sent from my SM-G955U using Tapatalk |
04-06-2021, 06:51 PM | #15 |
New tie rod done Sent from my SM-G955U using Tapatalk |
04-09-2021, 06:00 PM | #16 |
I guess it's time to upgrade the redneck panhard mount. New mount installed Sent from my SM-G955U using Tapatalk |
04-16-2021, 07:31 PM | #17 |
Couldn't keep the hacked up servo mount, so new parts. Sent from my SM-G955U using Tapatalk |
04-20-2021, 06:35 PM | #18 |
Let's do this. Out with the old rear. New rear. And I couldn't take the leaky shocks that I've rebuilt a thousand times it feels. It's blasphemous, but I've heard good stuff about the trx4 shocks. Ready to install. Sent from my SM-G955U using Tapatalk |
04-21-2021, 02:51 AM | #19 |
Pebble Pounder Join Date: Mar 2020 Location: Maine
I'm really curious what material and process you are using to make your axle housings. The detail is amazing and that texture makes them look like they're sand cast or laser sintered. They look great.
04-21-2021, 09:12 AM | #20 | |
| Re: Resurrection of plain jane ax10 axles Quote:
the grey parts are PA 12 printed with a HP Jet Fusion. Thanks. The black parts are from a markforge and from the ender 3 in the background Last edited by 500swmag; 04-21-2021 at 06:18 PM. | |
Resurrection of plain jane ax10 axles - Similar Threads | ||||
CR-01 Resurrection | nider | Tamiya CR-01 | 8 | 08-16-2023 09:54 AM |
Bomber Resurrection | MickSz | Axial RR10 Bomber | 5 | 04-11-2018 12:07 PM |
Bomber Resurrection | MickSz | Axial RR10 Bomber | 0 | 04-02-2018 12:28 PM |
Scorpion Resurrection | 06BlackTaco | Axial AX-10 Scorpion | 3 | 08-12-2015 09:13 AM |
Shafty Resurrection | tbilz | Axial AX-10 Scorpion | 13 | 06-02-2013 12:43 PM |
