07-04-2022, 06:08 AM | #1 |
Newbie Join Date: Jun 2013 Location: Aldridge, Walsall, UK
| Ax30464
Guys does anyone know what size piano wire I need to replace the stock ax30464 universal pin please ? I've got my son's scx10 stripped down waiting for the replacement Universal's and wanted to replace the pin straightaway so want to get the piano wire on order too Sent from my Pixel 5 using Tapatalk |
07-04-2022, 06:20 AM | #2 |
Rock Stacker Join Date: Apr 2011 Location: UK
| Re: Ax30464
Tried a hex pin? Sent from my iPhone using Tapatalk |
07-04-2022, 06:22 AM | #3 |
| Re: Ax30464
i thknk the pins are 2mm thick i could be wrong though the ones i used only lasted a few seconds first rock the tire touched SNAP on to the narrow xr mod |
07-04-2022, 06:24 AM | #4 |
| Re: Ax30464
I've got a spare hex pin I could use but that'll be the same as stock and I read the piano wire upgrade is best as the stock pins just break Sent from my Pixel 5 using Tapatalk |
07-04-2022, 06:29 AM | #5 | |
| Re: Ax30464 Quote:
Measure the hex pin and that’ll tell you what piano wire you need. Sent from my iPhone using Tapatalk | |
07-04-2022, 06:37 AM | #6 | |
| Re: Ax30464 Quote:
The rig... Last edited by lonleycreeper; 07-04-2022 at 06:41 AM. | |
07-04-2022, 06:39 AM | #7 |
| Re: Ax30464
I haven't got them yet so can't measure them Sent from my Pixel 5 using Tapatalk |
07-04-2022, 06:42 AM | #8 |
| Re: Ax30464
They are ax10 scorpion Universal's. Only option left for me to get really. My son has had the locked up rc otvd Universal's for the last 5 years and they were great but finally given up and they don't make the rebuild kits anymore. It's a stock ISH scx10 with 1.9s and a 35t brushed motor set up for trailing so nothing harsh. Just wanted to do the mod before I install them really. Plus I'm interested to see how the piano wires lasts so I could use same on my other original scx10s Sent from my Pixel 5 using Tapatalk |
07-04-2022, 06:48 AM | #9 |
| Re: Ax30464
ya the pins arent the week point the joint is just to small the dog bones are alot stronger but no steering angle ether cut your losses on those axles and upgrade to 10.2 axles or do the narrow xr mod |
07-04-2022, 07:06 AM | #10 |
| Re: Ax30464
I've bought these ones now so wil try the piano wire but yes I agree will have to upgrade in the future. Reluctant to tho as we've had these axles for so long and they are great ! Sent from my Pixel 5 using Tapatalk |
07-04-2022, 08:40 AM | #11 | |
| Re: Ax30464 Quote:
both will ether be narrow xrmods or dog bones cause steering angle wont be a issue on those projects but that sead the 10.2 have alot more parts support and there alot stronger than the original scx10 parts the gears can be a bit finniky to get to mesh right but once you got then dialed in there good to go | |
07-04-2022, 01:53 PM | #12 |
Rock Crawler Join Date: Mar 2021 Location: Santa Barbara
| Re: Ax30464
I've heard of people cutting up titanium drill bits for pins. Haven't heard of piano wire. What's the idea behind that?... they bend instead of break?
07-04-2022, 03:42 PM | #13 |
| Re: Ax30464 |
07-04-2022, 04:13 PM | #14 |
| Re: Ax30464 |
Ax30464 - Similar Threads | ||||
ax30464 install problem | 13in. | Axial SCX-10 | 4 | 08-08-2013 08:31 PM |
Broken CV Pin - ax30464 | SCX10Dingo | Axial SCX-10 | 6 | 07-07-2013 10:32 AM |
Axial Universal axle AX30464 for he honcho? | CHOPPERMECH11 | Axial SCX-10 | 1 | 12-28-2011 01:31 AM |
