09-08-2022, 11:25 AM | #1 |
Pebble Pounder Join Date: Dec 2007 Location: CDA
| SSD D60 panhard mount
Has anyone found anything that will work on the long discontinued SSD housings? Mine are in great shape still but I snapped the upper link/panhard mount my third run with my new Slate 2850
09-08-2022, 06:49 PM | #2 |
RCC Addict Join Date: Jun 2008 Location: Mudville
| Re: SSD D60 panhard mount
What rig? I just dropped some SSD Diamond (the plastic Pumpkin axles) under a VP Pheonix chassis and used the VP Pan hard mount that came with the chassis I bought from a buddy. It should work for the chassis side with a different rod end (longer likely).
09-08-2022, 07:18 PM | #3 |
| Re: SSD D60 panhard mount This is an OG scx10, I'm looking for the axle side panhard mount for the old SSD housings
09-08-2022, 10:47 PM | #4 |
The new rig has the panhard on the chub. Is that how it was on the og 10s?
09-09-2022, 03:45 AM | #5 |
Quarry Creeper Join Date: Dec 2009 Location: Strafford, NH
Take a look at the Rc4wd D44 panhard mount. I believe this will bolt up to a stock housing. I never owned a D60 housing, so I am not sure. Z-S2018
09-09-2022, 08:11 AM | #6 | |
| Re: SSD D60 panhard mount Quote:
They are different from a stock housing unfortunately. I may have to go back to stock housings or buy a VP panhard mount and see if I can butcher it to fit | |
09-09-2022, 08:44 AM | #7 |
if you post pics of the axle and broken panhard mount it would help i have the ssd d60 wraith housings and i think they use the panhard mounts for standered ar60s but i dont know how close the scx10 ssd axle and the stock axle are it might have to be custom made the gom panhard mount looks like it just clamps on to the axle housing it might work if your housing has round tubes and there close to the same size |
09-09-2022, 09:06 AM | #8 | |
https://imgur.com/a/0eBKUSx | |
09-09-2022, 10:55 AM | #9 |
the gom panhard mount might work with a little fudging kinda pricy though https://www.ebay.com/itm/31262582904...mis&media=COPY |
09-09-2022, 02:54 PM | #10 | |
09-09-2022, 03:22 PM | #11 |
This is what it looks like |
09-09-2022, 03:34 PM | #12 |
| Re: SSD D60 panhard mount |
09-09-2022, 04:03 PM | #13 |
move the top link to the top of the pumpkin worst comes to worst make a new one they dont look to hard |
09-12-2022, 07:21 PM | #14 |
Just wanted to update, took my housing over to a buddy's house and eyeballed his Vanquish panhard mount. With a small spacer and just elongating one hole it should fit pretty easily. Just need to order one up
09-13-2022, 07:49 PM | #15 |
Pebble Pounder Join Date: Oct 2009 Location: Tacoma
I might have one or two in my parts bin.
SSD D60 panhard mount - Similar Threads | ||||
New SSD HD D60 Aluminum Upper Mount | SSD | Axial Wraith | 1 | 10-13-2018 03:24 AM |
