Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Locked Up's SCX10 II Build
Old 11-08-2016, 07:07 PM   #101
Default Re: Locked Up's SCX10 II Build
Originally Posted by Locked Up View Post
Got a production prototype of the Max Clearance Trackbar installed.
Much better!
And of course we put in some OT Shafts for rear end beef.
No diff covers ... yet ... but we did add in Black Link Mounts to clean up at least part of the axle housings.
Look like its rubbing the servo horn in pic?
1beatjeep is offline   Reply With Quote
Old 11-08-2016, 07:33 PM   #102
Is trackbar available to buy?
aorquiz is offline   Reply With Quote
Old 11-08-2016, 08:15 PM   #103
SCALE PERFORMANCE PARTS
Locked Up's Avatar
Originally Posted by fr8cture View Post
Any way you could bend one like that and then bend it around the link mount aswell? Mines right over the link mount.
You moved your axle forward?
Locked Up is offline   Reply With Quote
Old 11-08-2016, 08:17 PM   #104
little bit yeah on my toyzuki
fr8cture is offline   Reply With Quote
Old 11-08-2016, 08:27 PM   #105
Locked Up's Avatar
Nope.
The servo arm screw sticks up and makes it look that way due to the angle of the picture.
Would be additional clearance with a shorter arm for sure, but it clears ... just barely.
Like paper thin barely.
You can imagine how much contact there is with the stock 4mm rod ends and a big servo arm like this.
But none of that is due to the trackbar, and still, you could raise up the servo with 1mm spacers to correct it in that case.
Old 11-08-2016, 08:29 PM   #106
Locked Up's Avatar
I suspect you might have to bend your own.
We have the means to move the trackbar mount forward with this conversion mount:
Pro CMS - SCX10 II Drop Mount
But only on a stock chassis.
Old 11-08-2016, 08:36 PM   #107
Yeah I was just curious if you were able to with yours I like how thin it is.
Old 11-09-2016, 07:31 AM   #108
Locked Up's Avatar
Without having it here to create one specifically for.... I'd be guessing.
I suspect you have the talent to bend up your own though using one of these:
90mm M3 Threaded Bar
It will really just depend on how much bend you need exactly. If it is too much, you might end up needing a longer one, but that also might be made up for with some longer rod ends.
Old 11-09-2016, 04:44 PM   #109
Very nice build Patrick! Love the Locked Up Blue paint!!!! Can't wait for some LURC goodies for my v2's
Bananaclip is offline   Reply With Quote
Old 11-23-2016, 07:26 AM   #110
Much better!
Will this trackbar available for sale?
Taper is offline   Reply With Quote
Old 11-23-2016, 07:39 AM   #111
Already is
Max Clearance Trackbar - SCX10 II
svt923 is online now   Reply With Quote
Old 05-29-2017, 10:22 AM   #112
Locked Up's Avatar
I know that eventually I will be wanting to push the wheelbase forward a bit so I went ahead an installed the Locked Up RC Pro CMS for SCX10-II.
This will also give me a more sturdy track bar mount on the chassis side, and I know I'll need that because I'm not one to back off the throttle in a bind.
This version was easier to install then the original SCX10 kit because you don't have to monkey around with opening up the axle.
I opted to keep the stock shock hoops for now but I will go with the Devil RC Aluminum Shock Hoops for SCX10-II once I figure out how I want to hide the body clips.
Old 05-29-2017, 12:04 PM   #113
How did you keep the stock battery tray? Isn't it too flimsy now?
Sent from my VS986 using Tapatalk
Old 05-29-2017, 04:53 PM   #114
Locked Up's Avatar
Nope.
Still plenty strong.
BUT, if you were concerned you could easily modify the stock servo mount and re attach it in the rear to gain back a mount point.
Long term we are looking to move a few things around so there will be more changes on this one.
Old 05-30-2017, 07:43 AM   #115
I ordered just the trackbar mount to see if I could use it on my Brazin Chassis.
I really dont like the 3d printed one I have now. Its really bulky, my tire rubs it when i turn.
redemon is offline   Reply With Quote
Old 07-13-2017, 04:00 AM   #116
Did you figure out how to hide the clips? This is something I've been trying to figure out with my own kit.
Kinison is offline   Reply With Quote
Old 07-13-2017, 10:53 AM   #117
Velcro ;)
I made a couple plates that the shock towers go through and are held on with body clips. Then between the posts is Velcro. Works like a charm. Can get pics of ya want.
LSXGMC is offline   Reply With Quote
Old 07-14-2017, 02:48 AM   #118
Originally Posted by LSXGMC View Post
Velcro ;)
I've seen a few people do this but have heard that the body can come off pretty easy should you roll it and I'll probably roll it a lot
It sounds like this is the best/easiest route to go though. How did you figure out how low on the body posts to place the velcro?
Old 07-14-2017, 07:43 AM   #119
Default Locked Up's SCX10 II Build
I used magnets before and although they're nice because they self-centre, the body popped off all the time. Hated it.
This Velcro mount I have is pretty strong, takes some convincing to get it off. My patches are about 3" x 1" front and back so lots of surface area.
For body post height I just put them in the holes up high without the set screws, then set the body on top and pushed down until it was at the height i wanted. Then removed the body and found the closest hole in the post for the set screws that worked.
Old 07-17-2017, 12:36 AM   #120
That's amazingly simple! I love it. Going to give that a shot, thanks!
Tags
axial, build, crawler, scale, scx10 ii
Locked Up's SCX10 II Build - Similar Threads
Locked Up's SCX10 - Trail Ready H2 Locked Up Axial SCX-10 197 02-12-2017 02:04 PM
Locked Up's Wraith Locked Up Axial Wraith 40 02-17-2016 06:32 AM
Locked Up's "Vuckin Double Cab" - A Chop Shop & Difuser build Locked Up 1.9 Scale Rigs 107 11-14-2015 08:37 AM
Locked Up's RC4WD Trail Finder 2 Build Thread Locked Up RC4WD Trail Finder 2 26 03-04-2012 08:08 PM
Locked Up's XR10 build Locked Up Axial XR10 60 03-06-2011 10:10 PM
