Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: When should i order
Old 06-07-2016, 05:59 AM   #1
Default When should i order
I had a look on all the build threads and most of the builds had encountered minor errors or parts missing.When will be the best to order the kit and have no issues at building the kit
Traulus is offline   Reply With Quote
Old 06-07-2016, 06:58 AM   #2
Default Re: When should i order
If you want to guarantee there will be no issues or missing parts, never get one.
Otherwise man up and buy your toy truck.
svt923 is offline   Reply With Quote
Old 06-07-2016, 07:12 AM   #3
^^ That. There are always some issues in new production (the Ascender had early pinion and driveshaft issues, the new Mojave 2 bodyset had some early body fitment issues, the Yeti had weak wheel hubs on early editions, etc.). Some get fixed quickly, some less quickly, and some not at all, which is where some ingenuity and/or the aftermarket come in. If you like the truck, just do it. If you get stuck, come back here for help.
new2rocks is offline   Reply With Quote
Old 06-07-2016, 07:42 AM   #4
So far I haven't found any missing parts in my kit. I've got the axles, links, shocks and transmission built without any major issues. I do think that there should be 2 more bearings inside the rear axle. I might buy some and go back and put them idk yet.
Sent from my XT1585 using Tapatalk
Waitwhatsthat? is offline   Reply With Quote
Old 06-07-2016, 08:06 AM   #5
I thought the same thing about the rear axle
WheelinKing is offline   Reply With Quote
Old 06-07-2016, 10:07 AM   #6
order one now. before it gets discontinued.
CM9000 is offline   Reply With Quote
Old 06-07-2016, 10:39 AM   #7
I don't think a couple little fitment issues some have experienced should stop you from ordering a kit. Just order one and build it.
Ty@Tekin is offline   Reply With Quote
Old 06-07-2016, 01:02 PM   #8
I didn't have any issues with building mine and the only thing that was missing was the trailer hitch.
Sent from my SM-G920V using Tapatalk
sf2000xj is offline   Reply With Quote
Old 06-07-2016, 03:35 PM   #9
Definitely will get one,as it looks awesome
Old 06-07-2016, 08:19 PM   #10
I've got mine mostly built. Just have the body and electronics to finish. I was missing a pin for the drive shaft joint. I also found another misprint in the manual. There is a small plastic piece that mounts to outside of the chassis. The screw for it also goes into the skid plate. It says to use a 12mm long screw. I learned the hard way that it is too long. I tried to force the screw in and ended up rounding it out. I used an 8mm long screw on the opposite side. Worked like a charm.
When should i order - Similar Threads
Just Placed An Order BigChevy17 Axial AX-10 Scorpion 0 05-29-2011 10:14 AM
Order skid plate Comments, Suggestions, and Help 0 12-23-2008 10:43 AM
order placed! 06yz250f Newbie General 6 08-11-2008 10:12 PM
just placed an order cammok5 Electronics 13 09-19-2007 09:43 PM
Order Up! RockRevolver Tamiya TLT Crawlers 12 09-01-2006 10:13 AM
