Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: servo winch
Old 07-03-2016, 08:33 PM   #21
Default Re: servo winch
Got this pic from a member on the Facebook forum prob gonna go with something similar
jdmguy760 is offline   Reply With Quote
Old 07-04-2016, 06:47 PM   #22
That's my truck. Lol
Sent from my SM-G900V using Tapatalk
scott83 is offline   Reply With Quote
Old 07-05-2016, 01:11 AM   #23
Lol my bad just thought people would like to see a option thanks again bud
Old 11-20-2016, 11:31 PM   #24
Quite the right fit! How's the performance and what hardware are you running there? Anything special to mount it up? Does running the line on top of the lead kill the usefulness of the high powered servo?
MeanTT is offline   Reply With Quote
Old 11-24-2016, 06:44 PM   #25
It's a cbe juggernaut winch. I have changed the setup a little adding a rod end for a guide. Replaced a screw with a set screw and threaded the rod end on. Works great.
Old 11-22-2017, 11:59 AM   #26
Where can you get that kind of servo winch?
Traulus is offline   Reply With Quote
Old 11-22-2017, 12:23 PM   #27
You can make it. Search the forum for servo winch you will find many options.
Ditchrat is offline   Reply With Quote
Old 11-22-2017, 12:26 PM   #28
Ihave serached,butno luck.Iwant tom make one of that,didn't figured out how to do it,as i see that something is moded in the servo so you can fit the spool inside
Old 12-14-2017, 10:35 PM   #29
KMS
KMS's Avatar
Here's one way to mount a KMS K3 style winch ..
https://www.youtube.com/watch?v=DiJL...W94Zw7uqbmqSIQ
KMS is offline   Reply With Quote
Old 02-26-2018, 04:07 AM   #30
Here is how I did mine. The spool is made out of the servo saver parts that came with the kit. I trimmed the one down so it would clear the links at full compression.
NitroDarwin is offline   Reply With Quote
Old 02-26-2018, 12:08 PM   #31
I need one with a spool inside tghe servo.the jugernaut servo winch is too expensive.A friend of mine is making them for like 15$
