08-21-2016, 09:20 PM | #81 |
Pebble Pounder Join Date: Aug 2007 Location: Switzerland
| Re: bilinvic's SCX10 II
Hi, nice rig! I may have overseen it but what compound of the KLRs are you runnig? Also what foams are you runnig? Cheers Rene
08-21-2016, 09:43 PM | #82 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
Thanxs....Silver KLR's with VooDoo Under 10 lb foams.
08-22-2016, 05:14 AM | #83 |
I wanna be Dave Join Date: Jul 2010 Location: Toronto
And how do you like those tires?
08-22-2016, 07:41 AM | #84 |
By far, the best tire and foam package I have ever used, the grip is absolutely incredible.
08-24-2016, 04:45 AM | #85 |
Pebble Pounder Join Date: Mar 2016 Location: Pacifica
Hi Bill, Do you have a brand & part # for the black glue gun glue ? or a link to the black glue ? Thats one killer build you have sir i am new to crawlers but not to RC. I have the same body that you have and will pick up my new SCX10 II this Friday from Jake's Performance Hobbies. I would also like to use your mods after i get some stock run time on it, if thats ok with you ? Thank you for your time and help, ~Darris Last edited by Say what?; 08-24-2016 at 05:11 AM. |
08-24-2016, 07:53 AM | #86 |
Here ya go Darris: 10pcs Black Hot All Temp Adhesive Glue Sticks Melt Car Audio Many Uses Free SHIP | eBay Have fun building your SCX10 II and of course, feel free to copy any mods I have done....you won't be disappointed. |
08-24-2016, 01:09 PM | #87 |
RCC Addict Join Date: Aug 2013 Location: Calgary - in the Great White North
| Re: bilinvic's SCX10 II |
08-25-2016, 10:18 PM | #88 |
Time for a servo change....the HH HV400 servos cannot be relied upon and therefore will go the spares stash for "on the trail" breakdowns. I took the waterproof Xpert WR-7701-HV out of my B1B Bomber and it now resides in the SCX10 II. So far this servo has performed flawlessly and hopefully it will continue to do so in my SCX10 II. I did order a ProModeler 420oz-in v4 servo with the intentions of using it this rig, but I think I will also leave that one as a spare for now when I receive it. FYI, the B1B Bomber is getting a new HH SHV500 servo.
08-28-2016, 08:40 PM | #89 |
Here's some video footage of last weekend's run.... |
08-29-2016, 05:40 AM | #90 |
Pebble Pounder Join Date: Apr 2011 Location: Madison
09-04-2016, 05:10 PM | #91 |
And yet another great crawl today with the SCX10 II Jeep G6....this machine is almost unstoppable and never fails to impress. Last edited by bilinvic; 11-11-2017 at 10:36 AM. |
09-06-2016, 10:26 PM | #92 |
The ProModeler 420 v4 servo arrived today. I installed it into the SCX10 II and I'll use the Xpert WR-7701-HV as a spare now. It's a slightly taller servo, so I used some spacers under the servo mounts to raise it up higher (approximately 2mm) so that the Panhard link would not push up against the servo arm when the suspension is compressed on the passenger side. I set the BEC to 7.3V Everyone raves about how good this servo is...so now it's my turn to put it thru it's paces!!! Last edited by bilinvic; 11-11-2017 at 10:37 AM. |
09-10-2016, 09:26 PM | #93 |
....another great video from nostopinLucR from our "bush whackin' trail run" a couple weeks ago. |
09-13-2016, 10:59 AM | #94 |
Rock Crawler Join Date: Apr 2015 Location: Paola, ks
Hey Bill, do you get a bind in the rear? When I push down on the rear of the truck I only get 50 percent travel or so. One wheel at a time I get full travel on that side. It looks like 2 of the links in the rear are binding on the Square skid on the bottom near the links mounts. Thanks for any help or advice. Sent from my SM-N920V using Tapatalk |
09-13-2016, 09:41 PM | #95 |
Yes, but it doesn't start binding until probably more around 75%. Although it does bother me, it's fine because my rig will never have both rear shocks fully compressed simultaneously...I don't jump it!!! lol
09-14-2016, 05:25 AM | #96 |
| Re: bilinvic's SCX10 II That is what i thought, but I was curious. I just wanted to be sure I didnt assemble something wrong. |
09-14-2016, 06:56 AM | #97 |
Rock Crawler Join Date: Jun 2011 Location: Tifton
I noticed mine does the same thing. Front compresses fine, the rear does not. Individually its fine though. |
09-16-2016, 11:48 PM | #98 |
I have gifted my SCX10 II with some Vanquish love! New 1.9 Vanquish Method 105 wheels. These are the latest versions that are 1.2" wide and they fit really well with the KLR tires and VooDoo under 10 lb dual stage foams. Compared to the narrower SSD wheels, the tire's sidewall doesn't bulge out as much and the tread surface is flatter.....not to mention, they look fantastic. Last edited by bilinvic; 11-11-2017 at 10:39 AM. |
09-17-2016, 04:22 AM | #99 |
Rock Crawler Join Date: Feb 2010 Location: Central/SE Ohio
Would you say this rig you've built out of the scx2 Is as fun or more fun to drive than your bombers?
09-17-2016, 05:06 AM | #100 | |
| Re: bilinvic's SCX10 II Quote:
I like your new wheels Are you still using the same Voodoo foams with the new wheels? If you are how is sidehilling with the 1.4" wide wheels? Thank You, ~D | |
bilinvic's SCX10 II - Similar Threads | ||||
bilinvic's R1 Build | bilinvic | G-Made Crawlers | 82 | 03-14-2018 07:52 PM |
bilinvic's Ascender | bilinvic | Vaterra Ascender | 169 | 11-14-2017 07:59 PM |
Video of bilinvic's RR10 Bomber | bilinvic | Videos! | 1 | 01-02-2016 07:20 PM |
bilinvic's Ultimate SCX10 '73 Bronco Build | bilinvic | Axial SCX-10 | 24 | 05-03-2015 05:55 PM |
bilinvic's Second Wraith Build | bilinvic | Axial Wraith | 11 | 10-14-2014 05:39 AM |
