09-22-2016, 07:17 AM | #21 |
| Re: Scx10 II = Wow! (Plus SSD DIY hex bolt tool)
I can see some jittering in the first vid. Since you swapped out both ESC and motor for the second vid, we can't determine whether motor or ESC is the root. Since the BLE firmware is based on the MMP, it would lead me to believe the Puller sensor board may have a sensor that isn't triggering proper. I know you have an email in with customer support right now in regards to the throttle jitters. Let them know about the servo and we will see what can be done for you. |
09-22-2016, 09:02 AM | #22 | |
Quarry Creeper Join Date: Oct 2009 Location: Reno
Would you suggest I try the MMP with the Puller Pro motor and the BLE Pro esc with the Pro4 motor (I've only run the Puller Pro motor with two BLE esc's and the pro 4 with the MMP esc), or just proceed with Customer Support on swapping the Puller and Servo? I'm definitely learning towards the motor being the cause, I've tried two BLE Pro esc's, both brand new, both netted identical stuttering. Quote:
09-23-2016, 04:54 PM | #23 |
Quarry Creeper Join Date: Mar 2016 Location: juneau
I'm running pretty much that exact same set up only difference is I don't have a stubby... I'm using a venom 5000 mah 11.1v 3s 20c and it runs smooth like butter Sent from my SAMSUNG-SM-G891A using Tapatalk |
09-23-2016, 05:29 PM | #24 | |
| Re: Scx10 II = Wow! (Plus SSD DIY hex bolt tool) Quote:
Sent from my SAMSUNG-SM-G891A using Tapatalk | |
09-23-2016, 07:38 PM | #25 | |
Rock Crawler Join Date: Apr 2015 Location: Paola, ks
Sent from my SM-N920V using Tapatalk | |
09-23-2016, 08:47 PM | #26 |
I got it geared 56/9t wheels speed is walking speed @ best. hill climbs no ,crawling YES! Sent from my SAMSUNG-SM-G891A using Tapatalk |
09-23-2016, 09:26 PM | #27 |
Rock Crawler Join Date: Dec 2007 Location: MERICA!
i had a similar problem with my stubby motor. when i installed the electronics i forgot to calibrate my esc. ounce i did that everything worked fine. im running mmp esc.
09-24-2016, 11:20 AM | #28 |
| Re: Scx10 II = Wow! (Plus SSD DIY hex bolt tool) |
09-24-2016, 05:24 PM | #29 |
No problem, good luck!
Scx10 II = Wow! (Plus SSD DIY hex bolt tool) - Similar Threads | ||||
DIY fuel injector pulse tool | BigSki | Tools, and Procedures | 12 | 08-02-2016 09:45 AM |
Scale bolt tool | Turtlejon | Tires and Wheels | 5 | 12-22-2014 12:52 AM |
rc4wd scale hex bolt tool HELP | discgolferlee | Tools, and Procedures | 20 | 06-15-2013 07:26 PM |
