10-04-2022, 08:13 PM | #21 |
Rock Crawler Join Date: Jan 2022 Location: st louis
| Re: Negative camber
The only way you have anything real camber up front is if you put the knuckles on the wrong sides. Besides that there will be a tiny out of slop in the font components but nothing abnormal if you assembled corrctly. FYI 7.5mm difference from top to bottom is a lot more than 4° of camber Sent from my SM-S906U using Tapatalk |
10-08-2022, 10:31 AM | #22 | |
Rock Crawler Join Date: Jun 2013 Location: Portugal
| Re: Negative camber Quote:
Everything seems in place. I've sold the camber gauge with the drifter, I measured the 4º with an android app but tried elsewhere to see if it was working fine. The method I've used to get those "7,5mm" was a bit sketchy and actually it is more : (blue line has 120mm and 4º) They are Axial BF Goodrich, almost 120mm tall. Every degree of camber changes a lot on the top of the tire | |
10-08-2022, 12:09 PM | #23 |
| Re: Negative camber
Have you measured the angle without a tire on the wheel? If there’s any camber the outside of the rim will not touch on a level surface.
10-08-2022, 05:17 PM | #24 |
| Re: Negative camber
Hmmmm... Just a thought. On road cars, race buggys/trucks, all require setup boards and various tools for setting toe/camber ect... Crawler guys tend to use the method of T.L.A.R. Or That looks about right... I have never measured toe or camber on a single crawler I own, and I doubt many guys here have. |
10-09-2022, 04:30 AM | #25 | |
Good idea! you guys can see that there's a noticeable amount of camber. I can't really check but I'm starting to think that the axle housing is slightly bent. | |
Negative camber - Similar Threads | ||||
Negative Camber with stock settings | amped up | Axial Yeti | 9 | 11-19-2015 04:00 PM |
Installed asiatees c hubs, now my camber is negative? | woodsman541 | Newbie General | 18 | 03-13-2015 06:17 AM |
Rear negative camber? | frdtrkguy | General Crawlers | 1 | 12-30-2007 08:30 AM |
negative ground systems? | slugzracing | Electronics | 3 | 05-24-2005 05:32 PM |
