![]() | #1 |
Quarry Creeper Join Date: Apr 2010 Location: Baraboo
| ![]() This is for the SCX10ii Kit setup ONLY. Not for the RTR. Cliff Notes: 1) Buy one MIP # 14390 for the rear 2) Buy one MIP # 9137 for the front. (use original pins from shaft to to axle not included setscrews) 3) ??? 4) Profit Rear: TowerHobbies.com | MIP X-Duty Rear C-Drive Kit Yeti After contacting MIP in regards to a set of shafts for the SCX10ii Kit form & they commented they had no plans at this time. Cross referencing kit parts with what parts bin Axial stole the drive shafts from, the Yeti rear shaft is equal. MIP # 14390 is the part; However, it must be put on backwards, the transfer case must be loosened up to get it on & then re-tightened, lastly the skid plate needs a little clearancing with a dremel directly under the cup or it will rub. I used Loctite Blue & not the included thread lock with the shafts. I have heard horror stories of the MIP lock being like Loctite Red (tough stuff) It magically fits past the bottom of the gearbox at full suspension compression... neat. It fits, it looks great & has that solid MIP feel. Front: I thought I would give the STRC STA31397R shaft insert a try. Also the STRC red drive cup covers. Unimpressive. That's it in a nut shell, unimpressive, it is undersized & sloppy. I'm actually fearful it will strip the rest of the shafts under high load. The drive cup covers are cute & I like those. I also have a set of the Axial # AX30501 drive cup covers lying around and they tightly fit the stock shafts. They make me feel better, but likely aren't needed. Be careful to not over tighten the setscrews on the collars, just snug is good. I know this isn't what these were made for but it cant hurt... Update Front: TowerHobbies.com | MIP Spline CVD DIG Kit Rear Axial AX10 The MIP # 9137 Dig Kit for AX10 is a perfect fit for SCX10ii front drive shaft. No extra parts needed, & re-use your OEM pins for pinning the shafts. -GLwagon ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by GLwagon; 01-12-2017 at 01:41 PM. |
![]() | #2 |
![]() | #3 |
I will try the MIP # 09137 as a front shaft & # 11117 long drive to see if it will work. MIP Spline CVD™ DIG Kit, Rear, Axial AX10 (1) #09137 The stock front is about 97mm end to end installed. The mip parts are 15mm + 15mm + 40mm of shat = 70mm tight (90mm extended?). The extended drive cup (long) # 11117 may be needed. http://www.miponline.com/store/mip11117.html Last edited by GLwagon; 12-18-2016 at 04:49 PM. |
![]() | #4 |
I wanna be Dave ![]() Join Date: Apr 2015 Location: Roseville, Ca
What's the front stock shaft measure bolt to bolt at ride height? I don't have the smaller dig mip but I have a wraith mip with different length ends I can measure for you. I would think either, dig with both extra long ends or maybe a wraith with short yeti ends will work. |
![]() | #5 |
Center to center on the output shaft to input shaft is 88mm
![]() | #6 |
A wraith MIP compressed with 2 short yeti ends is 88mm output bolt hole to output bolt hole. A yeti end is 9mm, standard wraith length end is 14mm and extra long wraith end is 19mm. That's measuring the pin on female/male to output bolt hole. |
![]() | #7 |
I wanna be Dave ![]() Join Date: Feb 2013 Location: NW Indiana
I have yet to tear up a stock WBHD axial drive shaft and I am running roc 412 3100kv motor with castles mmp... Is there a specific reason you want to run steel shafts?
![]() | #8 |
The only shafts I have blown up is old school plastic u-joint style. (like on my Tamiya CR-01) I like the quality of the stock parts it is a good design & has been solid. This is definitely an "option" upgrade & not needed, and if money is tight spend it on the better things like tires & rims. There is a little wear on the shaft where dirt & debris have rubbed near the T-case, & the sharp rocks that can get at the shaft that is exposed when I have been high-sided. The amount of wear or cutting into the shaft is more than I expected for the hours on the chassis. When I go out for a day it is a piece of mind & one less thing to worry about. The tightness & quality of MIP is second to none. I have MIP on my AX10 and they have been bullet proof. I consider the MIP to be an investment. Lastly, some times I like to spoil my self. |
![]() | #9 | |
| ![]() Quote:
I will source a shorty "dig" shaft & test. | |
![]() | #10 |
Quarry Creeper Join Date: Oct 2016 Location: Littleton
![]() | #11 |
Nice! The dig kit is is made of: # 08139 E-revo Male short # 08111 Ax10 Female Rebuild kit # 08105 The Wraith long male ball end # 11117 uses rebuild # 08105 from its original kit # 11116 The Traxxas Slash Females are # 10135 The Yeti # 14390 takes rebuild # 1147 (X-Duty) All use pin set # 10142 Your Sharpie marker has a broken tab. Last edited by GLwagon; 12-20-2016 at 11:30 AM. |
![]() | #12 |
![]() | #13 |
Rock Stacker ![]() Join Date: Sep 2015 Location: East Highland
For my rear male shaft, i used a SuperShafty Exclusive Shaft. Length is perfect. For the front, I'm waiting on my MIP dig shaft to arrive.
![]() | #14 |
Dig shaft is a perfect fit. OK, MIP, we have done the R&D. Now just put the kits together and get them out the door.
![]() | #15 |
sketchiness abounds... ![]() Join Date: Jun 2016 Location: Austin
Awesome thread, but MIP hasn't even released a Bomber kit yet, have to get SuperShafty's if you don't want leftover parts. I'm trying stock Axial shafts with out-of-production Carter FAB retainer rings at the ends. Silly me had also ordered those STRC aluminum shafts and during test fitting they are quite loose. Probably won't run them. Read a review that stated stock with Carter FAB parts are very rugged.
![]() | #16 |
By the OEM part numbers Axial Bomber Rear = MIP 14390. Here is a Bomber thread MIP Install Help Last edited by GLwagon; 01-12-2017 at 10:28 AM. |
![]() | #17 |
Pebble Pounder Join Date: Dec 2016 Location: Puerto Rico
has someone done this for the RTR Version? thanks in advance!
![]() | #18 |
Rock Crawler Join Date: Nov 2014 Location: Dells
![]() | #19 |
![]() | #20 |
Rock Stacker Join Date: Aug 2007 Location: Canada
Glwagon.. Im about to order the two parts you recommended in your first post.. About to build a scx10 2 Kit version... Was wondering what your long term results have been with them? Aside from the dremel work did they perform as expected? Thanks Sent from my SM-G950W using Tapatalk |
Mip front shaft in Rr10 | greengoblin | Axial RR10 Bomber | 11 | 12-30-2015 03:26 PM |
Mip drive shaft #14390 length? | navyeoseabee | Axial Yeti | 2 | 03-29-2015 07:25 PM |
