01-12-2017, 01:36 PM | #41 |
RCC Addict Join Date: Sep 2014 Location: Alberta
| Re: Xtra Speed axle
I'd like to see one with an SSD diff cover on it, or an RC4WD ARB cover.
01-12-2017, 08:02 PM | #42 |
Pebble Pounder Join Date: Jan 2014 Location: Eugene
| Re: Xtra Speed axle |
01-12-2017, 09:39 PM | #43 |
Pebble Pounder Join Date: Mar 2016 Location: westminster
| Re: Xtra Speed axle
The stock plastic diff covers fit without a problem. Check the first page as the original poster has them on his axle. I don't see why SSD wouldn't fit. Regarding the material, they are advertised as alloy so probably not 100% aluminum. It is a cast product but definitely not pot metal. Only time will tell how well these are made but for the cost, it is worth the gamble. I mean the beef tubes cost 55 dollars for one axle, so easy choice for me. Just a heads up, the overspray from the painting process may make the pinion bearing a little tight so some sandpaper or precise dremeling might be necessary but beyond that, no other issues. I use aluminum ball studs and they all fit along with my STRC lockouts and C-hubs. Last edited by triggerhapy; 01-13-2017 at 05:23 PM. |
01-17-2017, 01:58 PM | #44 | |
Quarry Creeper Join Date: Feb 2016 Location: Salt Lake City
| Re: Xtra Speed axle Quote:
I'm sticking with the XJ body on my II. I have scale items up in the rack and will be adding interior, wheel wells etc. These look like another great option to add low weight and fight the toppling XJ body. I've got the SSD SS lower links, C Hubs, knucks and Lock-outs with brass weights all around and Incision XD wheels on the way. Adding in these axles should provide a pretty good base for low weight. I've been almost exclusive with VP and/or SSD on this and my Bomber; but, 20 bucks and 100 additional grams per axle is hard argue against. Hopefully they'll hold up. Absolutely worth the risk for $20. | |
01-17-2017, 02:36 PM | #45 |
Quarry Creeper Join Date: Nov 2016 Location: Surrey
| Re: Xtra Speed axle
I am so tempted by these.....
01-17-2017, 02:41 PM | #46 |
| Re: Xtra Speed axle
Are these them? https://www.amazon.co.uk/gp/aw/d/B01...YFL&ref=plSrch |
01-17-2017, 02:52 PM | #47 |
Quarry Creeper Join Date: Oct 2016 Location: Littleton
| Re: Xtra Speed axle
That be them! Sent from my SM-N910P using Tapatalk |
01-17-2017, 03:38 PM | #48 |
| Re: Xtra Speed axle
£15 each free delivery that's a complete no brainer!
01-17-2017, 06:16 PM | #49 |
| Re: Xtra Speed axle
I agree!
01-17-2017, 07:56 PM | #50 |
Newbie Join Date: Dec 2016 Location: Raleigh
| Re: Xtra Speed axle
I just installed mine. I needed to fit the pinion bearing on both the front and rear axle, and it wasn't just light sandpapering. Eventually everything went together very easily and the weight difference very noticeable in hand. Happy overall.
01-20-2017, 09:43 PM | #51 |
Pebble Pounder Join Date: Dec 2016 Location: Puerto Rico
| Re: Xtra Speed axle
just ordered my set! lets see what happens |
01-20-2017, 10:03 PM | #52 |
Quarry Creeper Join Date: Feb 2012 Location: Verdi, Nevada
| Re: Xtra Speed axle
The price is right.....never look a Gift horse in the mouth, so they say
02-06-2017, 12:46 PM | #53 |
| Re: Xtra Speed axle
well received the axles on saturday! exactly took 2 weeks to get in my mailbox. installed the rear axle last night...ZERO issues whatsoever, everything fitted perfectly. hopefully can install the front one tonight or tomorrow! |
02-06-2017, 01:49 PM | #54 |
| Re: Xtra Speed axle
Good to hear, mine are sat on the shelf still in the plastic - saving them for the new 10.2 which should be here later this week - fingers crossed!
02-06-2017, 09:29 PM | #55 |
| Re: Xtra Speed axle
front axle installed! had to remove some of the painting to properly fit one of the bearings but it was a easy fix 😁 |
02-09-2017, 03:06 PM | #56 |
Newbie Join Date: Aug 2016 Location: Sask
| Re: Xtra Speed axle
Will theses work for the rear axle also?
02-09-2017, 03:22 PM | #57 |
| Re: Xtra Speed axle
Yes sir! Sent from my SM-N910P using Tapatalk |
02-10-2017, 07:14 AM | #58 |
| Re: Xtra Speed axle
yes its the same front and rear
02-10-2017, 09:09 AM | #59 |
02-11-2017, 02:21 PM | #60 |
Quarry Creeper Join Date: Jan 2006 Location: lehi, Ut.
| Re: Xtra Speed axle
Ordered mine 10 days ago.. paid $28 for both axles shipped.. can't wait until they get in my hands..
Xtra Speed axle - Similar Threads | ||||
Xtra speed "steel" SCX10 axle housing for everest 10 | Smokin' Joe | Redcat Crawlers | 9 | 12-24-2017 11:53 AM |
Xtra speed axle shafts on wraith? | dannyboyjdc | Newbie General | 1 | 11-21-2016 07:09 AM |
Xtra speed aluminium axle | Johan_Eriksson | Axial SCX-10 | 0 | 11-12-2016 01:37 PM |
Anybody see this yet, xtra speed sentinel | dubyas1989 | General Crawlers | 1 | 07-29-2016 09:41 AM |
xtra speed rc | roughneck | General Crawlers | 6 | 04-06-2014 09:17 PM |
