05-28-2017, 02:19 PM | #121 |
Rock Stacker Join Date: Mar 2009 Location: N/A
| Re: Gmade RSD Suspension? |
05-28-2017, 03:15 PM | #122 |
Rock Crawler Join Date: Feb 2017 Location: Northern Virginia
| Re: Gmade RSD Suspension? Glad I was able to point out what it was you were talking about for monster550 to clarify even though I was wrong. A large portion of the p/b aluminum housing is bare, only really a hole to stick a screwdriver in to adjust.
05-28-2017, 06:28 PM | #123 | |
Quarry Creeper Join Date: Dec 2010 Location: Hanford
| Re: Gmade RSD Suspension? Quote:
05-28-2017, 06:53 PM | #124 |
Quarry Creeper Join Date: Feb 2011 Location: Princeton Illinois
Yep..thats all i needed to know....thanks
07-06-2017, 08:29 PM | #125 | |
Not sure if the Bomber/Wraith beef tips were available as of that post, but I picked those up because the dimensions were close enough. They did end up working with a little effort. No need for drilling and retained the Gmade rod ends which seem high quality. Couldn't resist getting the AR44 brass link mounts for front and rear when I picked up the beef tips. Now for a re-dial in before this truck enters in a 1.9 class 2 scale comp this Saturday. Last edited by MattySlimz1987; 07-06-2017 at 08:31 PM. | |
07-28-2017, 10:36 AM | #126 | |
Newbie Join Date: Jul 2017 Location: Northern
07-31-2017, 04:09 PM | #127 | |
As far as leaking, again on these like I did the stockers, I only used greenslime on the seals and they barely leak at all, especially compared to the the originals. I've yet to come across someone who actually crawls and trails their truck and says that their shocks do not leak. If you actually use your truck and are crawling around tackling big lines, it will put the shocks to the test and they are going to leak, but when I say that these do, I mean very little as in slight residual. These have been on for a while now with many packs and I still do not feel the need to pull them off to be topped off with oil. Yes there are other options that you might not find leaking, but do they have that scale look? Is it going to work like it should for this special application? Even the $90 (for 2!) PL Ultra's leak, accounts from my own eyes, not sure if they were assembled correctly or not but there was oil on all 4 corners of the axles. If your looking at getting these for your truck, I say go for it. It was fun putting them together (no sarcasm intended) and the price is where they should be. Definitley buy them new so you can start from scratch on where to tune and so that you can use the piston count you want, I put in the 4 piston option on all 4. I hope this helps whomever has these on their shock option list in the future. Last edited by MattySlimz1987; 07-31-2017 at 04:12 PM. | |
08-01-2017, 09:49 AM | #128 |
08-30-2017, 09:54 AM | #129 |
Rock Crawler Join Date: May 2014 Location: Cluj-Napoca,Romania
Want to get a set of these,wonder what springs are soft enough for a scx10?
08-30-2017, 02:57 PM | #130 |
Quarry Creeper Join Date: Mar 2016 Location: Midlands
08-30-2017, 05:42 PM | #131 |
Quarry Creeper Join Date: Mar 2016 Location: juneau
I like these RsD piggy backs alot, im usin them with my RTR springs. I felt the springs they came with were a little stiff f or my liking. Also,They have no droop so I made a drop shackle type set up to help remedy that Sent from my SAMSUNG-SM-G891A using Tapatalk |
04-04-2018, 05:49 PM | #132 | |
Newbie Join Date: Mar 2018 Location: Denver
Are you running 93mm or 103mm Sent from my iPhone using Tapatalk | |
04-04-2018, 05:59 PM | #133 | |
These RSD piggybacks only come in 80,90 and 100mm. Mine have held up great so far with very minimal leakage utilizing AE greenslime and Teflon taping the threads. The Beeftubes “Beeftips” for Wraith/Bomber shocks fit these and help out with weight down low. | |
05-19-2018, 08:04 AM | #134 |
Newbie Join Date: Apr 2017 Location: USA
So to clarify this: To get these shocks you will need: 1) The RC4WD Springs Do you need to get new pistons? Or do you need to get new spring perches to run the RC4wd springs?> |
09-18-2018, 06:33 AM | #135 |
Newbie Join Date: Feb 2018 Location: Philippines
After reading through this thread numerous times, and doing further research on spring options, I got myself a set of 100mm RSD Piggybacks for my SCX10-1 Deadbolt. Some of you might ask why the 100mm and not the 90mm version? Because the compressed length of the 100mm RSDs are similar to the compressed length of the stock shocks with bumps stops. This puts the rear axle (at full compression) almost hitting the chassis rails. Furthermore it also adds 10mm of down travel for the suspension. These are the test cuts I did with a yellow 60mm spring. With the target of having the springs compress under the rigs weight at 2/3 the suspension travel (with 1/3 remaining up-travel), it didn't take me long to find the right springs for it. I used the rear springs off of an SCX10-2 kit (Cherokee) which uses the white springs rated at 1.13lbs/inch. I cut off one full coil and formed the open end to have a flat end and close it. This ended up at around 56mm long, about 2mm longer than the G Made springs, but it has given me good results. At ride height the shocks/springs are compressed at 18mm with 12mm of remaining upward travel. |
Gmade RSD Suspension? - Similar Threads | ||||
New G-Made RSD Shock Absorbers | LSXGMC | General Scale Talk | 21 | 01-22-2017 02:08 AM |
Gmade R1 Stealth Cantilever Suspension | bikerzee24 | G-Made Crawlers | 33 | 04-04-2014 08:15 PM |
Titanium Steering and Suspension Links for Gmade R1 | Blue Monkey RC | Chassis and Suspension | 0 | 02-14-2013 01:41 PM |
rustler suspension arms versus bandit suspension arms... | STEEL_CITY_CRAWLER | Non Crawler RC's | 5 | 08-30-2010 11:05 AM |
rsd and wheel speed | nuts5000 | General Crawlers | 7 | 04-07-2008 06:43 PM |
