01-04-2017, 07:00 AM | #1 |
Newbie Join Date: Dec 2016 Location: Pembroke Pines
| RC connector??? Xt60, xt90 or something else.
Hello all. Finishing up my II and need advice on connector selection. Haven't decided on an ESC/radio or batteries yet. I am placing an order for a radio. Wanted to order some connectors. What connector do you guys use. I have several other trucks and a drift car as well. I want to standardize on the connectors. What do you guys use on the SCX10-II? Thanks in advance. |
01-04-2017, 07:21 AM | #2 |
Quarry Creeper Join Date: Mar 2016 Location: Moses Lake
| Re: RC connector??? Xt60, xt90 or something else.
I use deans connectors in all my rigs.....Pretty easy to solder nice plugs. Sent From My LG V20 |
01-04-2017, 07:46 AM | #3 |
Deans, Traxxas, XT60, EC3; they will all meet your needs. Deciding from there is more of a personal choice. Running the most common connector in a group of drivers makes sharing packs possible. If your soldering skills aren't the best, EC3s are probably the easiest to install (no worrying about melting the plastic housing or needing shrink tubing). Packs will most likely come with either Deans or XT60s preinstalled for buy and run convenience. Traxxas connectors are very easy to plug and unplug while XT60s require much more effort. Generic XT60, EC3, and T-plug connectors can be bought in larger quantities much cheaper than Traxxas or genuine Deans if you have many cars or batteries. Personally, I use Traxxas but will be converting to EC3s in the near future. |
01-04-2017, 10:10 AM | #4 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
I don't like Deans just because there isn't enough to grab onto when unplugging the battery. They are very common though, so swapping battery packs between friends would be easy. I currently run Traxxas plugs on everything, but if I was starting over I'd probably run the XT60 because its easier to find small packs with those connectors on them. Sometimes I just wanna plug and play. |
01-04-2017, 07:56 PM | #5 |
Quarry Creeper Join Date: Dec 2016 Location: FL
XT60, Plenty of Packs out there with XT60 Connectors and they are pretty easy to solder. If I didn't have some Arrma Vehicles using XT90 I would be using XT60 more than likely as my own soldering ability sucks lol, tried Traxxas initially but I just kept having problems getting it done exactly correct everytime let alone seating them. In general though it really is personal preference and if your running with certain people all the time it might be a good idea to see what they are all running as was said that way you can share packs if needed.
01-05-2017, 08:26 AM | #6 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
Choose some batteries & then whatever plug comes with them, go with that. A lot of the US suppliers seem to come with deans, down here is easiest to get from hobbyking & the xt60 are more common. Personally if I never touch another deans plug I'll be quite happy, huge improvement over the old Tamiya plug, but xt60 or ec3/ec5 are a whole lot nice to solder & plug/unplug. That's my feelings anyway. |
01-05-2017, 08:31 AM | #7 |
After running dean's for years and switching to XT 60's I'll never go back.
01-05-2017, 09:38 AM | #8 |
Don't count out Tamiya connectors!
01-05-2017, 05:58 PM | #9 |
Pebble Pounder Join Date: Mar 2016 Location: Pacifica
| Re: RC connector??? Xt60, xt90 or something else. |
01-05-2017, 06:16 PM | #10 |
Quarry Creeper Join Date: Jul 2013 Location: PA
I run castle 8mm bullets or 6.5mm polarized connectors... seriously. Mainly because I run my batteries in everything from speed run cars, to boats, to crawlers... |
01-05-2017, 07:03 PM | #11 |
Rock Crawler Join Date: Aug 2007 Location: Philadelphia
XT60 is my favorite. I hate Deans with all my passion. They're harder to solder and they're harder to unplug. If you're friends still insist on running Deans it's very easy to solder an adapter if you want to share batteries. You can also buy adapters for a few dollars. Anybody who says they're bad at soldering probably just has a crappy iron or didn't tin their iron before using it initially. Soldering isn't hard. |
01-05-2017, 07:17 PM | #12 |
Pebble Pounder Join Date: Mar 2016 Location: westminster
01-05-2017, 10:06 PM | #13 |
Newbie Join Date: Dec 2016 Location: Comox, BC, Canada
I've been flying electric RC aircraft for 15 years now. Deans was the best we had for quite a while. They can be a real PIA to unplug, and soldering can be trickier than it needs to be. I switched to XT60's when they came out years ago and was never happier. As soon as I tried them, I switched all my batteries and packs to XT60. Much easier to unplug, great electrical connection, and easier to solder. Try it, you'll like it! I'm building an SCX 10 right now, and it will have XT60's.
01-06-2017, 01:55 AM | #14 |
Tamiya!
01-06-2017, 10:09 AM | #15 |
01-06-2017, 12:32 PM | #16 |
Quarry Creeper Join Date: Apr 2010 Location: Baraboo
The Chinese knock off deans power connectors solder much nicer & are much harder to melt. There is also Deans Micro 4-pin Sermose Power Poles (now duratrax) if you want finicky & harder to solder. |
01-06-2017, 12:40 PM | #17 | |
| Re: RC connector??? Xt60, xt90 or something else. Quote:
I still have about 50 sets of those mostly installed on old stick pack and esc's from my racing days. | |
01-06-2017, 12:50 PM | #18 |
Quarry Creeper Join Date: Jan 2016 Location: Boulder
I recommend being mindful of your most extreme arrangements. For example which of your vehicles has the least amount of space and which of your batteries' wires is the largest. I thought about switching from Deans to EC3 a few weeks ago, but ran into two issues which forced me to reconsider: 1) Whether the EC3 connector could be wedged into a tight space on my Axial Bomber 2) The thick wires on my new SMC batteries didn't fit too well into the EC3 bullets So, in the end, it was the outliers that had the greatest effect on my decision. I remain with Deans. |
01-06-2017, 12:56 PM | #19 |
RCC Addict Join Date: Apr 2015 Location: New Brunswick,Canada
this is all i use since day one xt60.......No need for shrink wrap. |
01-07-2017, 12:07 AM | #20 |
Pebble Pounder Join Date: Dec 2016 Location: Las Vegas
Just an FYI: XT60 is rated to 60 amps XT90 is rated 90+ For brushed crawlers XT 60 is fine but when you get in the 6S-8S range start thinking about a more robust connection. Like the XT90 with spark arrestors. I can't remember where I found that but if you want supporting literature I will dig it up. -M |
RC connector??? Xt60, xt90 or something else. - Similar Threads | ||||
looking for a Y connector | jon1197 | Newbie General | 5 | 12-17-2009 08:35 AM |
