![]() | #1 |
Newbie Join Date: Jan 2017 Location: Montréal,QC
I been trying to fit my Axial servo horn and they hit the panhard bar i heard some people change the straith rod end track bar by a bend one, for now i shim my servo, but i need advice and PICTURE with the bend track bar change. did i take the extra part did i get with the kit? Thanks |
![]() | #2 |
Quarry Creeper Join Date: Mar 2016 Location: Moses Lake
i know its not ideal but i upgraded my shock tower to these....... https://www.amainhobbies.com/st-raci...1380fs/p531044 they have other colors too. but gives you more room and an upgrade to the shock towers.....just a thought ![]() ![]() its just what i did. |
![]() | #3 |
Quarry Creeper ![]() Join Date: Dec 2016 Location: FL
Yeah, the Axial ones are a bit too fat for the clearance that it has by default. Racers Edge ones do fit fine though as they are slightly thinner. Had the same problem.
![]() | #4 |
Quarry Creeper ![]() Join Date: Mar 2016 Location: Midlands
I had to put 2mm spacers under my servo, and then bend the horn arm a little. Still no room for an end screw in the horn, it's just clamped on by the side screws. Seems like Axial left this area much too tight. I made some links with 4mm steel rod and rc4wd rod ends. With a couple of small bends i got better clearance to the servo and gained some suspension travel. ![]() ![]() Last edited by Dbx; 01-26-2017 at 12:17 PM. |
![]() | #5 |
Rock Crawler ![]() Join Date: Mar 2015 Location: Waltham
Is there a problem with shimming the servo that makes you want to change? I, too, have 2mm spacers to lift the servo up a touch. It's still solid.
![]() | #6 |
I wanna be Dave ![]() Join Date: Feb 2013 Location: NW Indiana
I used a racers edge servo horn, no shimming needed at all
![]() | #7 |
Well, Axial had their servo horn out before the 10.2 although now that this is out I am surprised axial has yet to actually redesign their aluminum servo horns so they actually fit their newest SCX10 Model. Probably will eventually of course, just need people complaining to them about the issue enough times to get something done about it.
![]() | #8 |
RCC Addict Join Date: Feb 2005 Location: Vancouver Island B.C.
I'm using the thin blue aluminum hitec servo horn with no clearance issues. Those axial ones are nice but do t really fit in a few situations where I tried using them. The racers edge ones that someone suggested are a bit thicker then the hitec one I have but still thin enough to work in most places and are plenty strong. I have a bent one but it's only from impacts
![]() | #9 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
I run the Racers Edge servo horn on a couple SCX10 IIs. It clears with no mods needed. They are a bit soft compared to some of the other servo horns out there, but I have only stripped one. That was on a heavy Bomber with lots of power and I was jumping (crashing) it pretty hard.
![]() | #10 |
Rock Crawler Join Date: Jan 2012 Location: middle TN
I have heard the vanquish servo horn fits well.
![]() | #11 |
Ok, but i already buy the axial
![]() | #12 |
Newbie Join Date: Jul 2015 Location: Australia
![]() | #13 |
![]() | #14 |
![]() | #15 |
Rock Stacker Join Date: Aug 2012 Location: Jacksonville, FL
I ordered a team losi one for my kit, ended up hitting also because it angles down (up normally). Luckily had a racers edge on my bomber so just swapped the two. Any reason you can't return the axial one you bought? Sent from my SAMSUNG-SM-G891A using Tapatalk |
![]() | #16 |
Pebble Pounder Join Date: Dec 2016 Location: Las Vegas
Food for though: I used the plastic one included in the kit because the aluminum one I purchased (losi something or other) wasn't long enough. I had to shim it up maybe a millimeter and then trim the ridges on the plastic horn. It works for me with no bending. -M |
![]() | #17 | |
| ![]() Quote:
Kinda depends on how you drive as well. I know I have stripped out more of those plastic horns than I care to think about, than again I have a fairly high torque servo, if your servo isn't above say 300 oz. in. than you can probably get away with it for awhile. All of mine are 400+ oz. in. so things tend to strip a Lot faster, especially when I flip them back to four wheels when they are on their side. | |
![]() | #18 |
Quarry Creeper Join Date: Apr 2010 Location: Baraboo
Start with the offset rod end to lower the panrod bar & go from there.
![]() | #19 |
I will try with both, i try just the one on the tower shock didnt fit as well After several try ( curved rod end, smaller one ) the only way to fit this axial servo horn, is to put a shim under the servo, I use the part who are supposed to hold the wire on the top of the servo, i've just put it between the servo and the servo frame. Without it, the horn hit the panhard braket of the shock tower and didn'T allow full steering angle. Thanks All Last edited by THX_138; 02-04-2017 at 09:52 AM. |
![]() | #20 |
Rock Stacker Join Date: Dec 2016 Location: Norway
| ![]() The axial horn has two mounting holes at 16 and 20mm. Therefore I suspect the 20mm vanquish would be the most suitable option. Hopefully someone who has installed a vanquish servo horn on an SCX10-ii can confirm.
Servo horn clearance | shiftauto | Axial SCX10 II | 14 | 07-21-2016 02:45 PM |
Wraith servo horn clearance? | StomperCrawler | Axial Wraith | 6 | 12-09-2014 03:39 PM |
Hitec servo horn problem??? | mnypit71 | Newbie General | 5 | 01-16-2011 03:24 PM |
Steering horn problem | CrawleR ModdeR | HPI Wheely King | 3 | 01-11-2011 02:34 PM |
