Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: How to shorten wheelbase on kit?
Old 02-12-2017, 08:29 PM   #1
Default How to shorten wheelbase on kit?
I am about to start assembly on my kit. I would like to use the axial Jeep Mighty FC body but I believe it is a shorter (11.3?) wheelbase.
Is it difficult to shorten the kit version wheelbase?
Do I need to shorten both the front and rear links or can I just do the rear?
Does anyone know of an off the shelf link that I could just bolt on and be done with this? I don't really want to fiddle with it too much. If doing this is a hassle I think I will just go with the stock Cherokee body.
Thanks for any advice you might be able to share.
scho0643 is offline   Reply With Quote
Old 02-12-2017, 09:28 PM   #2
Default Re: How to shorten wheelbase on kit?
[IMG]https://uploads.tapatalk-cdn.com/20170213/9b6c2ae1951844328024f74e050cc8bb.jpg[/IMG
The front stays the same. Mine is a kit also. I had a set of hot links racing links from my scx10-1 laying around.This what did to fit my FC body. I used the 122 links on the rear and pulled out the 2) 1 mm spacers on the lower links. I used 112 links in the upper but I added the 2mm spacers to the 112 links for a total of 4 spacers.. I moved the shock towers toward the most forward holes. I used some of the shorter drive shaft pieces from the kit. I swapped the front and rear frame bummer mounts around. The front is now on the rear vise versa.im not running the lower front body piece. In not running a bumper except the molded one on the body.
jeeptec is offline   Reply With Quote
Old 02-12-2017, 09:31 PM   #3
Old 02-12-2017, 09:32 PM   #4
Old 02-12-2017, 09:32 PM   #5
Old 02-12-2017, 09:33 PM   #6
I hope the short write up and pictures I posted helps.
Old 02-12-2017, 09:38 PM   #7
Old 02-13-2017, 08:43 AM   #8
any threads on how to get to shortest wheelbase on rtr? I cannot locate the search tool I use to use for this type of thing?
geauxktm, is offline   Reply With Quote
Old 02-13-2017, 09:27 AM   #9
Probably the same
Old 02-13-2017, 09:38 AM   #10
jeeptec that helps so much, thanks for sharing
Old 02-13-2017, 09:55 AM   #11
Sorry. I thought the rtr had all the same stuff except the transmission/gear box as the kit. That's why I put probably the same. Not trying to be a smart ass.
Old 02-13-2017, 10:35 AM   #12
I don't remember the numbers, but if you take the stock WB and subtract the WB you want that should give you how much to take out of the rear. Again I don't remember the exact numbers, but when I had planned on running my rc4wd blazer body on my v2 I was gonna try running a set of front links in the rear. The front is 3 linked, but the links are sold in pairs. I hope this makes sense.
monster 550 is offline   Reply With Quote
Old 02-13-2017, 12:47 PM   #13
Jeeptec , sorry for my lack of punctuation in my reply above.I was being sincere, your guide and pictures were exactly what I was looking for.
Old 02-14-2017, 02:55 PM   #14
Ok I did a little more research... the front upper and lower links that come on the SCX10.2 kit are approximately 0.9" shorter than the rear upper and lower links... (I know the front is a 3 link but the links ARE sold in pairs) parts # AX31419 and AX31421... so I could buy the metal part of the front links and just insert them in the rear link ends that come with my kit.
my question is: does having links that are 0.9" shorter mean that my wheelbase will be 0.9" shorter? I am guessing there is some geometry that might mess this up...
Old 02-14-2017, 05:23 PM   #15
I would think you'll get pretty close. As for links that are a hiatus too short spacers can be used as showed above. I didn't quite like my WB with a vaterra k5 body so this morning I made spacers for all 4 rear links and it worked perfect.
Old 02-18-2017, 09:05 PM   #16
I was playing with this a little while building my second kit for my proline blazer body. I need just over 11" and if I measured correctly the front links on the rear would put it right about 11.5. I'm going to make my own links when my stainless 4mm rod shows up. Just because I want it to be perfect
lilws6 is offline   Reply With Quote
How to shorten wheelbase on kit? - Similar Threads
How to shorten wheelbase by mm? lcbsc Vaterra Ascender 7 09-21-2015 09:38 PM
Shorten wheelbase beyond 11.3 xCoolHandLukex Axial SCX-10 15 11-07-2012 09:07 PM
How do you shorten the wheelbase on a honcho? RENEGADE< Axial SCX-10 5 11-30-2011 08:02 PM
Best way to shorten Wheelbase to 12.5 skkeeter Newbie General 5 08-04-2010 10:46 AM
Shorten my honcho's wheelbase for the new Proline Cherokee Body?? yellowpasta2000 Axial SCX-10 13 05-08-2010 03:17 PM
