Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Servo mount/ shock mount help needed
Old 04-02-2017, 08:01 PM   #1
Default Servo mount/ shock mount help needed
I tried searching to no avail. I've become a real stickler when it comes to buying parts because I've been burned too many times before and they end up being garbage... I've stripped out the forward shock hoop hole where it threads into the servo mount to where it is unuseable and wanted to know if anyone had any experience or suggestion for a metal replacement? I've found ones from strc, hotracing, or xtra speed but can't find any reviews... or should I just get another plastic one?
Thank you in advance!
Shafty_77 is offline   Reply With Quote
Old 04-02-2017, 08:38 PM   #2
Default Re: Servo mount/ shock mount help needed
I have been using g the hot racing ones for a little over a month now. No complaints. Fit perfectly, and good quality.
Sent from my XT1585 using Tapatalk
Waitwhatsthat? is offline   Reply With Quote
Old 04-03-2017, 05:47 AM   #3
Vanquish just came out with a set too. I'm still running plastic though.
fortyeightjake is offline   Reply With Quote
Old 04-03-2017, 06:48 AM   #4
Put a washer on it?
Jeepy84 is offline   Reply With Quote
Old 04-03-2017, 08:57 AM   #5
I'm using the Xtraspeed servo mount, fits pretty well but raised the servo up about 2mm towards the chassis which meant I had to get creative with a grinder so my servo horn would clear the frame.
QuesoDelDiablo is offline   Reply With Quote
Old 04-05-2017, 04:23 PM   #6
thank you for the responses went ahead and ordered the hot racing one
Servo mount/ shock mount help needed - Similar Threads
Shock mount needed for Bully V1 Ace138 RC4WD Bully 8 01-18-2014 08:29 PM
Getting my clod back out. Servo mount and shock mount ? LivDoug Tamiya Clod Buster 1 10-02-2010 12:20 PM
