04-19-2017, 10:39 PM | #1 |
I wanna be Dave Join Date: Sep 2005 Location: *
| Swaybar Setups
I've been asked a few times on my sway bar setup on the 10.2. I've ran both wraith front (long) and rear (short) to find the perfect balance for me. I first ran the Wraith rear (short) arms with piano wire torsion bar. This option will work just fine unless you want a little more articulation. If that is the case you'll want the front (long) arms to give more leverage on the torsion bar which will give you about .25" more articulation. These are the Wraith rear arms. I drilled a hole from both sides through the 10.2 rear bumper mount; slid the torsion bar through and attached the arms to the bar. The sway bar end links mount to the inside of the shock screws. This is the setup I'm running now. Wraith front (long) arms, piano wire through a OG SCX10 frame brace to keep it simple and clean. End links are still to the inside shock mount. I have also mounted these to the 10.2 axles but I'm looking for the pictures. Sent from my iPhone using Tapatalk Last edited by k9popo; 04-19-2017 at 10:43 PM. |
02-23-2023, 02:43 AM | #2 |
Quarry Creeper Join Date: Feb 2007 Location: Lleida
| Re: Swaybar Setups
Nice setup
Swaybar Setups - Similar Threads | ||||
Front swaybar | corefire | Axial RR10 Bomber | 2 | 05-14-2016 01:05 AM |
Rear swaybar | Lochrie2 | Vaterra Twin Hammers | 7 | 02-05-2016 08:23 PM |
swaybar help | smokinloon | Rally | 1 | 09-24-2015 08:10 PM |
