Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Boom Racing bevel and spool
Old 06-19-2017, 07:31 AM   #21
Default Re: Boom Racing bevel and spool
To avoid it I put a custom thickness spacer between both pinion bearings, no axial preload and no play, and another custom thickness spacer between outside pinion bearing and driveshaft
Taper is offline   Reply With Quote
Old 06-19-2017, 06:49 PM   #22
Originally Posted by IVIaarten View Post
Helical gears create a force in the axial direction when turning, so one side will be pulled in, and the other pushed out. If you haven't shimmed one of the sides correctly, this will cause extra wear, most likely on the side that gets pulled in (in your case likely the front).
Thanks for the tips( A lot of money and time spent ) really got to shims properly next time.
Another reason was I find myself hard to find correct size in shims. Ask few local hardware shops, they just said: we do not carried the size, as these shims are way too small for regular use.
Teng is offline   Reply With Quote
Old 06-30-2017, 01:29 PM   #23
After the first time I spent the front screws I replaced both lockers with FI lockers from LURC and changed to some stainless screws (with no black dioxide coating) kept with the stock 30t/8t. Still havent had any problems, running holmes brushless power. May get some spares just in case.
MattySlimz1987 is offline   Reply With Quote
Old 06-30-2017, 01:36 PM   #24
Mine show up Monday, I will post some pics and some initial thoughts then.
Sent from my SM-N910P using Tapatalk
Shawns303 is offline   Reply With Quote
Old 07-01-2017, 12:00 PM   #25
Did you get these deep set Boom gears? Still haven't seen real world results on them. After somebody had mentioned their was a flaw in design, I held back.
Old 07-01-2017, 02:20 PM   #26
on a friends new rig he has VP spools heavy-duty gears front and rear. Stock ratio in the rear overdrive in the front. Been holding up fine with a roc 3s and 4S batteries. Not one problem yet
m1009cucv is offline   Reply With Quote
Old 07-01-2017, 02:45 PM   #27
Order a set online. For example, I got a Kyosho 5x7 shim set with 10 each of 0.1, 0.2, 0.3mm shims for less than 10$.
Edit: 8$ shipped worldwide from Amain. Get some bigger ones for the sides (can't remember diameter) and you're set. Maybe a set of .5mm ones too.
Ninomaniac is offline   Reply With Quote
Old 07-03-2017, 04:59 PM   #28
Just received these, will hopefully install tonight. Spool and spur came already bolted together. Hardware is m2 not m2.5, shouldn't really matter since they are keyed together but I think other manufacturers could benefit from larger bolts if they are going to copy the Axial lack of interface.
Old 07-03-2017, 07:44 PM   #29
So I have played with them a little bit and the bevel gear and the spool are a super tight press fit. As long as the gear mesh is good and the gears are hard enough, these are going to be bombproof!
Old 07-05-2017, 07:42 AM   #30
Have them installed and they are super smooth. I am going to punish them this week, should be able to burn 5-6 7000mah 3s batts through them and will see what they look like this weekend. The Xtra Speed one piece bevel and locker didn't even make it through 1 4000mah battery. Fingers crossed!
Old 07-05-2017, 10:15 AM   #31
Have them installed and they are super smooth. I am going to punish them this week, should be able to burn 5-6 7000mah batts through them and will see what they look like this weekend. The Xtra Speed one piece bevel and locker didn't even make it through 1 4000mah battery. Fingers crossed!
So how much does the stock setup weigh in at?
Sent from my SM-N920V using Tapatalk
Motorider is offline   Reply With Quote
Old 07-05-2017, 10:17 AM   #32
I will have to bring it to work tomorrow, I don't have a gram scale at home.
Old 07-06-2017, 09:34 AM   #33
Alright. So I have run 21000mah 3s power through these so far, mostly at full throttle. It was only three hours of running, but three brutal hours. I am super impressed with the wear, more of just a polishing. These are the only gears I will run from here on out, was so sick of having to finish a trail in 2wd because of those damn broken bolts. Worth every penny.
Old 07-06-2017, 10:21 AM   #34
Good news; however, I have not had the displeasure of a broken bolt yet. I only have about 120hrs logged on mine though.
Old 07-06-2017, 10:26 AM   #35
You should knock on wood now!
Old 08-11-2017, 10:45 AM   #36
Still holding on strong? I'm about to pull the trigger
dpcardoza is offline   Reply With Quote
Old 08-11-2017, 10:48 AM   #37
No issues at all! I have been beating the snot out of these and am about to order another set for my swb build. I won't even consider using anything but these from here on out.
Old 05-01-2018, 08:32 PM   #38
Getting ready for the season, opened my axles up to clean and lube and found this. This has been driven hard for nearly a year, I was blown away.
Old 05-01-2018, 10:12 PM   #39
I'm impressed.
bilinvic is offline   Reply With Quote
Old 05-02-2018, 12:27 AM   #40
This is good to know.
Boom Racing bevel and spool - Similar Threads
Front bevel /spool issue Shawns303 Axial SCX10 II 11 11-17-2016 03:55 PM
Boom Racing? Truckmechanic304 Axial SCX-10 1 06-07-2016 12:52 AM
Boom racing G2rebel Vaterra Twin Hammers 16 01-15-2016 03:10 PM
Boom racing jdsusername Axial RR10 Bomber 26 01-05-2016 11:08 AM
RC4wd steel bevel shaft and alum. spool? wyattburp Tamiya TLT Crawlers 1 04-19-2007 11:49 AM
