06-10-2017, 01:15 PM | #1 |
Quarry Creeper Join Date: May 2017 Location: Bellevue
| I hear squeaking
Just completed building the SCX10II kit. Runs great but I've got some squeaking going on when driving. I think I've narrowed it down to the rear end. Is this a sign of a bad bearing out of the box? Sent from my iPhone using Tapatalk |
06-10-2017, 03:01 PM | #2 |
Rock Crawler Join Date: Feb 2017 Location: Northern Virginia
| Re: I hear squeaking
Very common thing with a lot of crawlers and noticing sounds due to slow speeds. I'm very confident the bearings are fine. Try putting some wd-40 on all the driveshaft ends where they connect to the outputs. Don't use grease though because it will attract dirt and other particles that will assist in premature wear. |
06-10-2017, 03:55 PM | #3 |
WD40 is not a lubricant and will attract crap. Don't use it.
06-10-2017, 05:02 PM | #4 |
| Re: I hear squeaking Well suggest something to to the user than.... Its actually the ball inside the driveshaft yolk, it gets rust residue on it, lithium grease or theres some type of dry grease to use and it won't attract things. *Update- There is a certain WD-40 to use. https://www.webstaurantstore.com/wd-...oUdRoCz0Pw_wcB Last edited by MattySlimz1987; 06-10-2017 at 05:14 PM. |
06-14-2017, 09:34 PM | #5 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
I used dry Silicone spray it doesn't attract dirt and stuff once it drys Sent from my SAMSUNG-SM-G935A using Tapatalk |
06-15-2017, 06:54 PM | #6 |
Rock Crawler Join Date: Apr 2015 Location: Paola, ks
Wd40 has a dry lube that works well. I'll get a pic in a few. Quiets things right down. Goes on wet but it dries very quickly Sent from my SM-N920V using Tapatalk |
06-15-2017, 08:01 PM | #7 | ||
| Re: I hear squeaking Quote:
matty linked to that one already in his post.. Quote:
06-16-2017, 07:39 PM | #8 |
Quarry Creeper Join Date: May 2013 Location: on top of the rocks
I will give out my best keep secret for the best rc lube on the planet. I know it has given me a winning performace advantage in 35 years in rc. Its called Dry Ice and its made by Sullivan. Alcohol based dry Teflon. Bearings, bushings, ball studs,hinge pins and bores, gears, anything that moves. It does not attract dirt if let to dry. If you think im kidding, remove the shield from a bearing and clean with brake clean to remove all grease, soak in Dry Ice lube, let dry and replace shield. Any bearing will perform 10 times better and last longer, even ceramics.
06-17-2017, 12:59 AM | #9 |
Quarry Creeper Join Date: Sep 2015 Location: Bakersfield
| Re: I hear squeaking |
06-19-2017, 06:01 AM | #10 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
WD40 is suck, wear out my Mountain bike's chain so fast. Now my rig use mountain bike dry chain lube and it works great |
I hear squeaking - Similar Threads | ||||
squeaking | shiftauto | Axial Yeti | 18 | 03-22-2016 09:00 PM |
Axial Wraith Squeaking? | mamcleo | Axial Wraith | 12 | 05-07-2012 06:50 PM |
Summit Squeaking | Cole Moore | Newbie General | 4 | 03-05-2011 12:04 PM |
novak 55t squeaking | jahoban | Electronics | 20 | 08-18-2009 10:48 AM |
Squeaking sound from motor | garinx2000 | Electronics | 10 | 02-06-2008 04:40 AM |
