My LC70 Build Hi all Starting my first crawler build with a new RTR SCX10.2 coupled with the hot Killerbody LC70 body. First on the list is to get the body lower but the stock shocks seem to be limiting how low i can go. Ive see a few people with what looked like a lowered setup. Just wondering if anyone had any ideas Will update this thread as i get into it. http://i199.photobucket.com/albums/a...psgiy3bh0n.jpg http://i199.photobucket.com/albums/a...pslyerx8my.jpg |
Re: My LC70 Build You can buy shorter shocks or you can install internal limiters in your shocks to drop the height. I think you should also invest in smaller tires. Those are too large for that body. You will have lots of body rub because the wheel wells are small and those tires are massive. |
Re: My LC70 Build Quote:
I completely agree with Jato. Tires are way too big. I faced the same problem on my build, went with the original size 1.9 Rock Beasts and it makes a difference. I also had my ride height too tall for my liking. I limited the shocks 5mm internally to essentially drop them to 85mm shocks and I'm more than happy with the result. This truck goes anywhere! BEFORE https://uploads.tapatalk-cdn.com/201...3e8a38b7f9.jpg AFTER https://uploads.tapatalk-cdn.com/201...ffb04ef563.jpg |
Re: My LC70 Build The Pro-Line 1.9 Super Swamper TSL in non XL form, is another great option. Not too big and not too small 4.35 in. compared to a lot of the 1.9 XL variants that are mostly 4.75 in. |
Re: My LC70 Build Cheers mate Just looking at tyres etc now Managed to get the body lowered on the weekend, needed to put together some lower shock towers for the rear, thats already made a big difference. I've now got rubbing at the front though, desperately need some new tyres Thinking about the G-made SR03 wheels Any other reccomendaitons on wheels much appreciated, i wish the K02's were a bit smaller, really like the look of them. |
Re: My LC70 Build I think the SR-03s would be a perfect match for this truck |
Run the Prolines then. Way better tire anyways, a little smaller, and very scale. The compound is much softer and sticker than Axials too. Here's a comparison photo I took: https://uploads.tapatalk-cdn.com/201...4c24a702c7.jpg |
Re: My LC70 Build After staring at a few options decided I'd go a set of the 1.55 Boom Racing Yota's with the 1.55 Pitbull Growlers Should look pretty good on the LC I reckon. |
Can you measure the offset on the Boom Racing Yota's? Sent from my iPhone using Tapatalk |
Re: My LC70 Build Will do mate when I get them |
Re: My LC70 Build LSXGMC. What kind of truck body is that?! Sent from my iPhone using Tapatalk |
What body is that Sent from my iPhone using Tapatalk |
Re: My LC70 Build Body is custom K10 made from an RC4WD Blazer. Quote:
Be sure to take some photos! Those will look awesome on your truck. |
https://uploads.tapatalk-cdn.com/201...739cc707a5.jpg I'm guessing you're having the most issues with the rear shock hoops. You might want to look for a cantilever shock setup for the rear on the 10-2, the rear bed really needs to sit on the frame rails, for which the 1.55's will help a lot (doubt it'll work with 1.9's). |
Re: My LC70 Build Dinky link cantilever system for the rear! It's what I'm doing with mine on a scx10 1.0 and the bed sits flush |
Re: My LC70 Build https://uploads.tapatalk-cdn.com/201...f725b8a000.jpg Here’s my scx10ii with an lc70 Sent from my iPhone using Tapatalk |
Re: My LC70 Build Hi, nice Toyota... i wonder if yu found the cantiliever shocks, if so, please post a photo! |
Re: My LC70 Build KillerBody LC70 in the Woods https://youtu.be/ol3PpJkc-_k |
