Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Spring for Traxxas big bores
Old 06-27-2017, 01:12 AM   #1
Exclamation Spring for Traxxas big bores
Trying to finish dialling in my suspension. Currently using big bores all round with Axial 14x70mm springs. For the front, I've decided i need something in between the black (1.04) and the purple (1.43). Is there a spring from other manufacturers that might fit the bill? Thanks.
maverick67 is offline   Reply With Quote
Old 06-27-2017, 03:03 AM   #2
Default Re: Spring for Traxxas big bores
The "Big Bore" shocks from the likes of a 2wd Slash and whatnot? Losi XXX-SCT springs fit. Assuming that you are using the rear length shocks, you'll need the Losi 2.5" or 2.75" springs. They come in a bunch of different rates, with the absolute softest rates jumping to 2.75" long.
If I remember correctly, the numbers Traxxas uses for their rates are a little weird, and so they might not coincide directly with the Losi in/lb rates.
Check HERE to see which springs I'm writing about... I think that there are a few more rates than what come up in the search, but that should point you in the right direction.
micro racer is offline   Reply With Quote
Old 07-02-2017, 12:57 PM   #3
I'm running Losi gold 1.4 rate in the front stock axial spring in the rear for my big bores. I thought the Losi 1.4 were too stiff on the rear.
jeeptec is offline   Reply With Quote
Spring for Traxxas big bores - Similar Threads
Traxxas big Bores stianl Axial AX-10 Scorpion 2 06-15-2009 03:51 PM
