Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Better shock option/fix?
Old 07-07-2017, 07:29 PM   #21
Default Re: Better shock option/fix?
I just got my Traxxas 2660 Big Bore shocks installed today. Wow are they ever smooth, nice upgrade from the Icons. I don't think they look that bad, plus I'm never at an angle to see them when running anyways.
LSXGMC is offline   Reply With Quote
Old 07-07-2017, 10:17 PM   #22
Looking into Big Bore shocks. Pretty good option? They are more budget which is good. What springs are yall running?
Ryanf58 is offline   Reply With Quote
Old 07-07-2017, 11:06 PM   #23
Look to be promising out on the trails!
If you have the desire for more weight down low at a bargain, I recommend the Beef Tips for the Bomber/Wraith at $11.99. Their dimensions are set up for a 14x-- size spring with a 3.5mm shock shaft hole. Not sure the exact dimensions on your Big Bores, but they look relatively the same size as my RSD's with the spring diameter 15x46 and shock shaft 3.5mm.
A very small strech of the bottom coil got it over its seat. I'm very pleased with the results. I'm utilizing the 0.4 rate springs in front and a little stiffer 0.8 in the rear. I have a lot of work to do tonight on this 10ii for a scale comp tommorow. I have to get this thing on par with some TRX4's that are bound to be seen at the starting gate.
Also would like to note I'm glad I don't have to worry about RCC having weirdos jump on your post and start spamming about bank loans in different languages..
MattySlimz1987 is offline   Reply With Quote
Old 07-08-2017, 02:16 PM   #24
Originally Posted by Shawns303 View Post
I run these with traxxas big bore xrings. Leak free and work with the Axial 12.5x60 springs.
4pcs 90mm Aluminum Shock Absorber Set fr AXIAL SCX10 1/10 RC4WD D90 CC01 Crawler | eBay
Sent from my SM-N910P using Tapatalk
What size x-rings did you get? I have these currently on my rig, the x-rings that fit the Icon's were too big for these if I remember correctly.
blackjack12982 is offline   Reply With Quote
Old 07-08-2017, 03:00 PM   #25
Tra2362. It's a wiggle, but they fit. I take out the white center spacer between the two orange o rings. Install the xring first then the two o rings on top of it.
Shawns303 is offline   Reply With Quote
Better shock option/fix? - Similar Threads
Kyosho Shock Option Zombi Axial Yeti 2 05-27-2015 04:11 AM
A new scale 90mm shock option! 2500hdon37s Axial SCX-10 3 04-11-2011 07:07 AM
shock fix bubbaskyjacker Newbie General 5 11-18-2010 01:28 AM
Losi Shock Fix? doors4u Losi Mini-Rock Crawler 26 08-17-2010 01:01 AM
a fix for a more flexable shock yoda316 General Crawlers 4 01-15-2005 09:10 PM
