Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Some Anti torque twist transmissions
Old 07-07-2017, 03:03 AM   #1
Default Some Anti torque twist transmissions
Found some anti torque twist transmissions on google lately. Hope this thread could benefits for some rc fans here and I believe some of these trans can be purchased on ebay or maybe some online store?
Teng is offline   Reply With Quote
Old 07-07-2017, 07:09 AM   #2
Moderator
JatoTheRipper's Avatar
Default Re: Some Anti torque twist transmissions
What makes it anti-torque twist?
Old 07-07-2017, 07:48 AM   #3
the transmission spin in different direction. Says the front drive shaft in reserve direction and the rear in forward direction .
Old 07-07-2017, 08:02 AM   #4
Hi Jato, have you check this video started from 0.37? https://youtu.be/3RJmeUQA5U0
Old 07-07-2017, 09:03 AM   #5
My Ascender is setup with the driveshafts spinning in opposite directions and the counter rotating shafts really do remove torque twist with the extremely large catch of all 4 tires being firmly on the ground. If the weight shifts off one end (which occasionally happens in crawling), all benefit of the counter rotation is gone.
It is cool to hit the throttle on flat ground and have the truck stay upright though.
svt923 is offline   Reply With Quote
Old 07-07-2017, 06:10 PM   #6
Hot Racing also makes an anti torque twist transfer case for the 10.2 kit trans.
SCREAMER is offline   Reply With Quote
Old 07-07-2017, 07:07 PM   #7
Moderator
How did you pull that off?
Old 07-07-2017, 07:18 PM   #8
These are all great posts. I am a firm advocate for anything that reduces torque twist. That being said, can we possibly get some links to these? I have tried to find them but my Google-fu is embarrassingly sub-par today. I appreciate it fellas. Thanks in advance.
Ok, I believe I found the correct Hot Racing transfer case.
http://hot-racing.com/?partnumber=SCXT38RTC01;c=1020
CR4NK is offline   Reply With Quote
Old 07-07-2017, 07:27 PM   #9
Changing output shafts on the GCM t-case and flipping the rear axle.
The Seemingly Eternal Evolution of SVT's Ascender
Old 07-07-2017, 10:25 PM   #10
Mmmmm. Cheeze Berger. Dlux Fab
TheLetterJ is offline   Reply With Quote
Old 07-08-2017, 10:25 AM   #11
From your ascender thread, svt923...
"The results of my experiment: torque twist gone completely with the catch of all 4 wheels needing to be on the ground. If you are in a situation where 1 tire (especially the front) isn't on the ground or where most of the weight is shifted to one end, it will still twist in the direction of the axle rotation on the side with the majority of the weight."
I imagine this applies to ALL counter rotational applications, transmissions, t-cases etc.?.?.? I manage to get a wheel/corner up at least twice every time I'm out crawling so not sure if this is the way I want to go. Your input is appreciated.
Some Anti torque twist transmissions - Similar Threads
Anti Torque Twist solution Chris-NL Vaterra Ascender 30 04-01-2016 08:10 PM
Ascender Sway Bar (Anti-Torque Twist) stillsmokin875 Vaterra Ascender 11 09-20-2015 02:18 AM
The V-link anti torque twist experiment. miller Axial AX-10 Scorpion 38 12-12-2009 10:56 AM
V-link anti torque twist experiment. miller Axial AX-10 Scorpion 2 11-26-2009 08:47 PM
Tlt with anti torque twist cantilevers ? setecastronomy Tamiya TLT Crawlers 3 01-01-2009 06:56 PM
