Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Integy 3gear transmission won't work with the stock driveshafts?
Old 07-09-2017, 07:43 PM   #1
Default Integy 3gear transmission won't work with the stock driveshafts?
Ok, so I was fitting my SCX10.2 kit crawler with the Integy 3 gear billet gearbox that I picked up brand new. Its mounted in, ready to hook up driveshafts... and the rear output, the retaining cup that keeps the cross pin in place, wont clear the motor plate.... do I just need to grind the play a little or should I just go order a factory Axial motor plate? Can I use a factory spur cover on the Integy trans if I use the factory motor plate? it certainly doesnt fit with this plate as the tabs to secure the cover are not even close! thanks!
4drmopar is offline   Reply With Quote
Old 07-09-2017, 08:03 PM   #2
Default Re: Integy 3gear transmission won't work with the stock driveshafts?
I would grind a little as long as you are not real close to any mounting holes.
blumaro is offline   Reply With Quote
Old 07-10-2017, 10:02 PM   #3
I was waiting for Integy to chime in on there product. Haven't seen many post's from them recently.. might've not been able to handle all the criticism
MattySlimz1987 is offline   Reply With Quote
Integy 3gear transmission won't work with the stock driveshafts? - Similar Threads
Integy driveshafts pike2350 General Scale Talk 11 02-09-2012 04:43 PM
integy driveshafts fordsuperduty Axial AX-10 Scorpion 10 03-24-2011 09:57 AM
help with integy driveshafts prof_fate Axial AX-10 Scorpion 12 12-25-2010 01:43 AM
Integy Driveshafts? wantekc Axial AX-10 Scorpion 14 05-08-2009 12:21 AM
