Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Desperately need help...toyzuki v2 tranny
Old 07-12-2017, 06:32 PM   #1
Default Desperately need help...toyzuki v2 tranny
My output shaft will be too short to hook up a drive shaft. What is wrong here? Using the ax31134 shaft. I have tried to shim the shaft to bring the mesh in better. When I do that, it makes the output shaft even shorter. If I rotate the shaft, it's longer, but it will not quite go through the bearing on the spur side. Ugh. What a pain.
Sent from my SM-N920V using Tapatalk
Motorider is offline   Reply With Quote
Old 07-12-2017, 06:36 PM   #2
MODERATOR™
EeePee's Avatar
Default Re: Desperately need help...toyzuki v2 tranny
You need help formatting a post and resizing pictures also.
EeePee is offline   Reply With Quote
Old 07-12-2017, 06:53 PM   #3
Thanks. I'm just using tapatalk. Say thanks to photobucket. Not sure how to fix it. Looks normal on my phone
Old 07-13-2017, 02:18 AM   #4
Make sure you use 'enter' once or twice to go to a new line before adding the picture, and the same after the picture.
Dunno about the resizing.
IVIaarten is offline   Reply With Quote
Old 07-13-2017, 04:19 AM   #5
I'm using tapatalk. There is no entering spaces.
Old 07-13-2017, 04:34 AM   #6
Yes
There
Is
Old 07-13-2017, 06:34 AM   #7
Yes
There
Is
I just use the picture add at bottom of post. I can not add spaces or text between the images. I know how to do pictures on forums. This is a problem with tapatalk.
I
Know
I can enter spaces.
Old 07-13-2017, 06:36 AM   #8
Might be a version difference between apps then. When I add a picture in my Tapatalk app it shows the URL in my message and I can add enters to my hearts content.
Old 07-13-2017, 06:48 AM   #9
I'll try it right here. I'm adding the image from my phone directly to the tapatalk. It will not allow me to see the any url. I am uploading the image to tapatalk servers. No 3rd party hosting. It works out great on my tapatalk app, but it must be messing up the standard forum. I'll Check it out on my work pc in a bit.
Old 07-13-2017, 07:32 AM   #10
Yes
There
Is
so on my pc the images are very large. Your screenshot is also very large and does not fit on my 1080p display.
Old 07-13-2017, 10:26 AM   #11
hehehe, EeePee is going to be so happy with us
Old 07-13-2017, 02:07 PM   #12
MODERATOR™
EeePee's Avatar
Yep
Old 07-13-2017, 03:39 PM   #13
Mine doesnt normally show the formatting either, just the pictures. If I go back in afterwards though and edit the post I can see them then....
JSterrett is offline   Reply With Quote
Old 07-13-2017, 03:40 PM   #14
Like so....
Old 07-14-2017, 05:29 AM   #15
despite all the talk about picture formatting, I was able to solve my own problems with the transmission. This thread can be deleted since it poses no useful information. I am starting my build thread now.
