08-11-2017, 11:40 AM | #1 |
Newbie Join Date: Dec 2012 Location: Honolulu
| First scx10 ii
Ok guys so my first 1.9" scx 2 kit should be here today I'm normally a 2.2" guy but I wanted to get into somthing Well scale my intent was to built it and replace as break And maybe upgrade if I'm in the area if that makes sense I am super stoked but is there any thing I should know before Hand you know the 2am omg now I have to wait till tomorrw Things ? Im going to use a mamba x 1900 kv And my tried and true futaba 9157 For starters also axial bead locks cause I hate glueing tires I just feel like it's a waste of tires and time and energy and glue and Perfectly good swear words any words of wisdom on the scx10 2 kit would be appreciated |
08-11-2017, 03:26 PM | #2 |
Rock Stacker Join Date: Sep 2015 Location: Simi
| Re: First scx10 ii
I just built mine a few weeks ago. All straight forward as can be. Just build it and drive it. Don't over tighten the screws. I did glue the wheels and don't mind them. I believe that less rotational mass the better. I did use SS hardware when building mine and AVID bearings. Not needed just my preference. I also used the Vanquish topshaft in the trans and Locked up RC panhard to gain clearance. Once I finished the build I then moved the bumpers in closer to gain clearance. Enjoy the build |
08-12-2017, 08:54 AM | #3 |
Quarry Creeper Join Date: Aug 2015 Location: Worthington
| Re: First scx10 ii
I had to shim rear axial input to get gear mesh good, front is good because it is pushed but rear gets pulled in. And I had in/out play in spur gear in transmission, a pin thru the plastic spacer and exrta hole in shaft removed the play
08-12-2017, 09:27 PM | #4 |
Rock Crawler Join Date: Feb 2017 Location: Northern Virginia
| Re: First scx10 ii
2 things only that should be done to the kit version where I personally believe they are manufacturing and/or design flaws, and they have to do with play/slop. Play in moving mechanical parts really get to me maybe not as much to others. 1. I and many others highly reccomend the transmission top shaft from Vanquish USA. This is to iradicate the slop/play in the output shaft (spur gear shaft). http://www.vanquishproducts.com/scx1...ion-top-shaft/ 2. 2 5×11×4 bearings where Axial omissed for reasons I'd rather not even mention. These are to be put on the rear axle shaft towards the middle where the clamping lockout's screws are to be tightened up (off topic but NEVER over tighten those), position it in the cut-out in the plastic housing. This will keep the rear end having play inside the axle housing, which IS noticable. You may have them in your parts bag and they may have updated the manual since the latest release of the new batches of this model since it was on hold for months, I considerably doubt it though. http://www.fasteddybearings.com/trax...-2rs-10-units/ This is where the bearings should be installed, I used Traxxas style blue sealed bearings. Last edited by MattySlimz1987; 08-12-2017 at 09:38 PM. |
08-12-2017, 10:27 PM | #5 |
| Re: First scx10 ii
I cant see how that bearing not being there would allow the axle to slide around, the hex, pin and wheel will keep the axle where its supposed to be. I think the bearing will allow for more support of the axle shaft and also give the housing more solid support for the clamping lockout to clamp on but thats it. mine were missing and I had zero slop in my axles... Last edited by allanon1965; 08-12-2017 at 10:29 PM. |
08-13-2017, 12:50 AM | #6 |
| Re: First scx10 ii
There is quite a bit of slop from left to right without the bearings. I can't think of anthing else it could be. After I put in bearings my play was gone. Everything remained the same including the torque on the wheel nuts. I think there might even be a YT video on this particular "not so big issue". If there isn't, there should be.. heck, I'll do one if theres none. Something to do tommorow with the free time on my hands..
08-18-2017, 01:26 PM | #7 |
| Re: First scx10 ii
So the bumpers looked a little well plastic so I threw so bed liner on and looks a ton better Sent from my iPhone using Tapatalk |
08-18-2017, 01:30 PM | #8 |
| Re: First scx10 ii
Next on the list figure out the stereo system I'm thinking maybe somthing like this what you guys think ? Sent from my iPhone using Tapatalk |
08-21-2017, 02:40 AM | #9 |
| Re: First scx10 ii
Body's done still waiting on interior Sent from my iPhone using Tapatalk |
08-21-2017, 02:41 AM | #10 |
| Re: First scx10 ii Sent from my iPhone using Tapatalk |
08-21-2017, 12:49 PM | #11 |
Rock Crawler Join Date: Mar 2014 Location: Dallas, Texas
| Re: First scx10 ii
You may be disappointed with 1900KV. I run 3550 in mine on 3S - sensored of course!
08-21-2017, 01:14 PM | #12 |
| Re: First scx10 ii
I have a 3800 in my bomber And also a 2850 lying around I've been hearing that a lots about the Lower kv just not enough wheel speed I'll probably use the 2850 for now I'm going to order some Holmes hobby Motors I heard they are outstanding What's the difference in the stubby and reg cans ? |
08-21-2017, 03:34 PM | #13 | |
| Re: First scx10 ii Quote:
Best of luck! | |
08-21-2017, 04:55 PM | #14 |
| Re: First scx10 ii
I kinda figured that but I don't want to assume anything ThNks for your input |
First scx10 ii - Similar Threads | ||||
New Lost Coast Backwoods RC Low CG Battery Boxes for SCX10 and SCX10 II! | RPP Hobby | RPP Hobby | 0 | 08-07-2017 02:38 PM |
Axial SCX10 ll, SCX10, Gmade Sawback 4LS, Vaterra Ascender K5 From Malaysia. | RCWin | Videos! | 2 | 12-01-2016 08:23 AM |
Rc4wd trailfinder 2 axial scx10 hilux scx10 rubicon jeep | TAFF1969 | Scale Videos! | 0 | 03-08-2016 07:11 AM |
Newbie. Ordered CRC ScX10 rtr and SCX10 jeep kit. | Mattdaddy1974 | Axial SCX-10 | 15 | 07-11-2015 02:50 PM |
