Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Steering Linkage Shock
Old 08-17-2017, 07:25 PM   #1
Default Steering Linkage Shock
A 100mm shock to replace your steering linkage,
I did this setup on my old RC4WD Stomper and It worked out good.
It protected the servo, Worked the same as a servo saver more or less and look kind of cool also.
I did stiffen up the shock with a small outer spring and gas tubing in side the main body of the shock.
The shock was a little big for the setup but a more scale RC4WD 100mm shock would look better.
Thinking about doing this setup on my SCX10 II
Stomper Fan 777 is offline   Reply With Quote
Old 08-18-2017, 06:04 AM   #2
Default Re: Steering Linkage Shock
Or you could just use one of these. These are purpose built.
RC4WD Superlift Adjustable Steering Stabilizer (65mm-90mm)
RC4WD Superlift Adjustable Steering Stabilizer (90mm-120mm)
Now these don't really act as a servo saver as your idea might, but for trailing and crawling a servo saver is not nearly as useful or necessary.
ebbet is offline   Reply With Quote
Old 08-18-2017, 12:49 PM   #3
Why do u need a servo saver for?
Traulus is offline   Reply With Quote
Old 08-18-2017, 06:08 PM   #4
A servo saver just basically is just to protect the servo gears under stress.
Watch this YouTube video this is the same setup using a shock as a servo saver as in my post.
https://youtu.be/0OvomVUhfLE
Old 08-18-2017, 08:17 PM   #5
I think the question is why do you need a servo saver for your trail truck? The video you shared was for a guy using that application in a FOFF rig. The steering servo is under a lot more stress in that application and a servo saver is more warranted. With a trail or crawler rig, a servo saver is not necessary because the stress on the servo is very limited. In fact, as long as you have your end points set, a servo saver should not be necessary at all. It would do more harm than good. You want your servo to be able to hold a line. With a servo saver, if it gets under load, it will shift back and not hold the line. Not sure I am explaining this right. Maybe someone else could do better.
Old 08-18-2017, 08:48 PM   #6
I have broke two Savox 1230 cases in mine, granted, it took some gnar hits to do so. I have not had any issues since I relocated the servo to be parallel with the bumper. The shock does look cool though!
Sent from my SM-N910P using Tapatalk
Shawns303 is offline   Reply With Quote
Old 08-19-2017, 12:12 PM   #7
I am not that dumb,i know what a servo saver is used for,but what you shown me,it's a high speed truck where forces are way increased then in a trail truck
Old 08-19-2017, 12:14 PM   #8
Maybe your setup was wrong,but i hadn't broke a single servo on my trail truck,unless its a cheap chinese crap
Old 08-19-2017, 12:19 PM   #9
Wrong as in stock.
Steering Linkage Shock - Similar Threads
Steering linkage jeeptec Axial SCX10 II 4 06-10-2017 08:14 PM
Steering linkage High pressure EnRoute Berg 1 01-04-2014 07:50 AM
Steering linkage ?s Big Daddy Axial SCX-10 6 07-13-2011 09:59 PM
steering linkage sam.oc235 Axial SCX-10 6 01-24-2011 04:31 PM
inside tyre touches steering knuckle / steering linkage murky123 Axial SCX-10 4 10-06-2010 04:46 PM
