09-28-2017, 04:11 PM | #1 |
Rock Crawler Join Date: Apr 2015 Location: Paola, ks
| Locked up FI spool and OT shafts
So I purchased some locked up FI spools and OT shafts for the rear to take up the slop. Problem is, I can't get the shafts into the spools. I can force/wiggle them in about half way. With 4mm left to go in, I feel I will damage the differential or axle if I push any Harder. Furthermore, how will I get it out to work on the diff. I know I could probably file the a bit, but should I have to file new parts? The stock shafts fit perfect with no slop. I also shimmed the left bearing to get better mesh. Thanks for any help. Sent from my SM-N920V using Tapatalk |
09-28-2017, 05:00 PM | #2 |
RCC Addict Join Date: Sep 2014 Location: Alberta
| Re: Locked up FI spool and OT shafts
The whole idea behind his stuff is zero slop, and yes it requires filing sometimes. I put them in a previous truck I had and they were snug as hell and very difficult to get apart, so slight filing would have helped there. I’d suggest filing down until you’re happy with it.
09-28-2017, 05:01 PM | #3 |
Quarry Creeper Join Date: Feb 2011 Location: Nevada
What he said. Beat me to it.
09-29-2017, 01:52 AM | #4 |
Thanks guys, Im going to polish them a bit to get a push in fit that does not require a slide hammer for removal.
Locked up FI spool and OT shafts - Similar Threads | ||||
Locked Up RC - FI Spool | Locked Up | Locked Up RC | 121 | 04-26-2017 10:20 AM |
currie axle scx and locked up fi spool | zion23 | General Crawlers | 2 | 01-07-2015 01:24 AM |
Locked Up RC - FI Spool | Locked Up | General Crawlers | 3 | 07-05-2013 08:00 PM |
