11-14-2017, 10:35 AM | #81 | |
| Re: New SSD Pro44 Axles Quote:
If I had to guess I'd say I'm the only one to run the extensions and likely the first to test them. If the designer tested them then he needs to fire himself for designing them wrong. On the stock housing I had to cut the outer part of the splines off and slide the extensions 10mm further onto the housing than they were designed to do so the shafts didnt have 10mm of thrust in & out of the locker. In that pic I losted I used an ssd rear and cut the tube ends off, did some internal dremel work on the extensions and slid them further onto the housing. This time it is solid but they are far from a "bolt on" like they would have been if they were designed right in the first damned place! | |
11-14-2017, 04:25 PM | #82 |
Quarry Creeper Join Date: Feb 2016 Location: Salt Lake City
I had seen this asked somewhere but can't find it now... have you given any consideration to building axle shafts with integrated shock/link mounts? integrating the lockouts was great for scale. Integrated shock/link would be awesome for scale. Get rid of those unsightly bolts. If not SSD, would love someone else to make this. I do not have any clue how these are made. If by lathe, I understand the reasons; but, if they are cast in a mold... go for it. |
11-15-2017, 10:00 AM | #83 |
Quarry Creeper Join Date: Dec 2015 Location: Sutter
| Re: New SSD Pro44 Axles |
11-15-2017, 10:15 AM | #84 |
Rock Crawler Join Date: Aug 2007 Location: Philadelphia
| Re: New SSD Pro44 Axles It's 3 screws and really the screws just keep the tube from sliding laterally. Most of the structural load is taken by the case itself. The tubes slide farther into the case than it looks. I had my doubts when I got my Pro44 set but after assembling them I have zero concern about structural stability.
11-15-2017, 06:34 PM | #85 |
There is an option coming that looks a helluva lot like that axle but with a full length truss to not only correct the horrific geometry but to ensure it stays together under harder usage.
11-15-2017, 06:42 PM | #86 |
Rock Crawler Join Date: Mar 2017 Location: Rubicon Trail
11-15-2017, 06:48 PM | #87 |
11-15-2017, 07:12 PM | #88 |
11-22-2017, 02:45 PM | #89 |
Newbie Join Date: Feb 2016 Location: Norway
| Re: New SSD Pro44 Axles What's up with this? That can't be right? Sent from my iPhone using Tapatalk |
11-22-2017, 02:46 PM | #90 |
Quarry Creeper Join Date: Oct 2016 Location: Littleton
11-22-2017, 03:01 PM | #91 |
11-22-2017, 03:20 PM | #92 |
11-22-2017, 05:10 PM | #93 |
l think there is a final machine process. I’d email SSD. I’m sure they will take care of you.
11-22-2017, 06:33 PM | #94 |
11-23-2017, 02:41 AM | #95 |
11-23-2017, 02:41 AM | #96 |
RCC Addict Join Date: Oct 2014 Location: UK
11-23-2017, 02:43 AM | #97 |
11-23-2017, 06:05 AM | #98 |
11-23-2017, 10:18 AM | #99 |
RCC Addict Join Date: Aug 2008 Location: Paulina
Will these be offered as complete axles?
11-23-2017, 10:38 AM | #100 |
| Re: New SSD Pro44 Axles The max size is the same at the largest point (ring gear area). Pro44 are actually slighty smaller in other areas due to the more angular/scale pumpkin shape.
New SSD Pro44 Axles - Similar Threads | ||||
Ssd pro44 axle | redemon | Chit Chat | 36 | 10-07-2017 06:15 AM |
SSD Pro44? | 4RunnerKid | Axial SCX10 II | 5 | 10-06-2017 03:28 AM |
SSD Axles | GravelDuster | Axial SCX-10 | 2 | 12-19-2015 10:10 AM |
