01-20-2018, 12:52 PM | #81 |
Quarry Creeper Join Date: Sep 2013 Location: Norway
| Re: New SSD Diamond Pro Axles |
01-23-2018, 06:40 AM | #82 | |
RCC Addict Join Date: Oct 2014 Location: UK
| Re: New SSD Diamond Pro Axles Quote:
We already releaseed an OG upgrade kit: Pro44 CMS & Titanium Link Set / V2 Conversion for SCX10 Yes we will be making some Venture parts in the coming months. Working on offset tubes now. But there isn't a lot of room to play with really. | |
01-23-2018, 12:25 PM | #83 |
RCC Addict Join Date: Aug 2005 Location: Oceano, CA
02-07-2018, 04:51 PM | #84 | |
Quarry Creeper Join Date: Feb 2016 Location: Salt Lake City
I understand that you can't give a date; but, are we looking at weeks or months for a release? Keep up the great work with solid desirable products. | |
02-09-2018, 03:23 AM | #85 |
Rock Crawler Join Date: Aug 2005 Location: Asia
i'm really digging the way these axels look. I hope this wasn't asked before, but une question before i purchase a set... whats the difference between the Diamond and the Pro44, aside from the aesthetics, is there a benefit to running any of the two? |
02-10-2018, 01:45 AM | #86 |
Rock Stacker Join Date: Jan 2018 Location: oregon coast
been running my diamond pros for a couple months now and i love them! however, on the front axle, the axle tubes at the short m3x5 bolts that connect the them to the diff housing have stripped. i just noticed tonight that a couple of them were backed off pretty far, so i pulled them out to reapply blue loctite and found that the threads from the axle housings came with them. not sure what caused that, but i think it should hold together for a while. i was thinking about getting lockoutless rear tubes for the rear housing before, maybe i'll pick some up now and move the rear housings to the front.
02-10-2018, 09:07 AM | #87 | |
Quarry Creeper Join Date: Feb 2015 Location: Norway
EDIT: What wheelbase do i end up with on this kit? Says its for 305 wheelbase, so im kinda confused if the wheelbase will be 12 or 12.3. Since all scx2 are 12.3 and all. Last edited by Rcdood; 02-10-2018 at 09:12 AM. | |
02-11-2018, 11:44 AM | #88 | |
I wanna be Dave Join Date: Aug 2004 Location: san jose
03-27-2018, 06:23 PM | #89 | |
03-27-2018, 06:26 PM | #90 |
04-05-2018, 09:47 AM | #91 |
Newbie Join Date: Feb 2015 Location: USA
I've been running a set of these on an SCX10ii with the Deadloc Racing counter rotating transfer case (TNT). I flipped the front axle 3rd member to achieve opposite rotation and had to do a bit of shimming on the gears to get a smooth rotation. You need to flip one axle, I chose the front for my setup. So far, this has been great and very little torque twist. I love this setup and these axles!! I have not had any screws back out yet, but I will keep an eye on these. I used thread lock on initial assembly. I do not bash or abuse the rig (just scale trails), that also may be a factor. |
06-26-2018, 11:48 PM | #92 | |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
If you flipped the bevel gear, How come output pinion gear on the bottom? On my AR60 axle I just need to flip the ring gear and it is all done. Can you post me a picture? And explain me in detail? Thank you P/S: I would like to use this Dimond pro axle on my SCX10 II with CheezBurger Transmission | |
06-27-2018, 01:53 AM | #93 |
Rock Crawler Join Date: May 2018 Location: USA
I did this by accident and had my tires spinning in opposite directions lol.
06-28-2018, 10:04 AM | #94 | |
Rock Crawler Join Date: Dec 2012 Location: Utah
06-28-2018, 10:48 AM | #95 |
Quarry Creeper Join Date: Mar 2014 Location: san antonio
| Re: New SSD Diamond Pro Axles I’ve been very very pleased with these axles. Great product! Sent from my iPhone using Tapatalk |
06-28-2018, 11:17 AM | #96 |
I love mine as well. Get high centered a lot less than stock axles.
08-21-2018, 09:58 AM | #97 |
Quarry Creeper Join Date: Apr 2016 Location: Canada, Ottawa/Gatineau
To those that own the SSD diamonds, how is the plastic center section holding up to abrasive wear? Thanks D |
08-21-2018, 12:14 PM | #98 |
Quarry Creeper Join Date: May 2013 Location: on top of the rocks
I would like to try a set as I am building another set of ar44's. My question is which to choose, these or the pro 44's. My concern is like others, how well does the plastic centers hold up to rock abuse. At least with the pro 44's you sell an optional alloy diff covers that help with rock rash, strength, and maintenance access. In the future my suggestion would be offer a diamond diff armor OH AND WRAITH/BOMBER LENGHT TUBES.
08-21-2018, 12:15 PM | #99 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
08-21-2018, 12:17 PM | #100 |
| Re: New SSD Diamond Pro Axles Brother...... CMS/panhard doesn't effect wheelbase. You can run the same kit on any wheelbase rig...... |
New SSD Diamond Pro Axles - Similar Threads | ||||
Currie F9? Rockjocks? SSD Diamond Axles? | 701scaler | Axial SCX-10 | 24 | 04-02-2016 08:13 AM |
