Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: New SSD Diamond Pro Axles
Old 08-21-2018, 01:19 PM   #101
Default Re: New SSD Diamond Pro Axles
Originally Posted by valheru View Post
To those that own the SSD diamonds, how is the plastic center section holding up to abrasive wear?
Thanks
D
Mine have held up great. I would highly recommend them.
jason02ws6 is offline   Reply With Quote
Old 08-21-2018, 01:19 PM   #102
I have the diamonds and the plastic has held up incredibly well and slides over rocks really well. You do lose some of the scale look and ease of maintenance but from a performance standpoint they are pretty awesome.
dpcardoza is offline   Reply With Quote
Old 08-21-2018, 01:20 PM   #103
Someone chime in on this, who has a diamond in front and how chewed up is it from rock rash, lets see those pics.
THUNDER PRO is offline   Reply With Quote
Old 08-21-2018, 01:29 PM   #104
Would say approximately 6-8hrs of run time.
Old 08-21-2018, 01:29 PM   #105
I can post pictures this evening when I get home. Iíve had then both front and rear for a few months and mainly do most of my crawling in limestone and granite. There is hardly any deformation on the center sections.
Old 08-21-2018, 09:09 PM   #106
Old 08-22-2018, 08:33 AM   #107
Thank you for all the responses to my question.
I have a 14 lbs D90 pickup class 2 scaler and I managed to destroy a front Boom Racing Phat axle which is cast zinc in less than one G6 and 3 local scale comps.
Therefore, I was looking at replacing my Phat axles with SSD SCX 2 diamond and the plastic center had me worried, but seeing the way the seem to wear and at the price they sell replacement center section, I might just go with those.
D
valheru is offline   Reply With Quote
Old 08-22-2018, 08:59 AM   #108
I wouldn't steer you wrong Val..... Buy the SSD housings (Highly recommend the SSD brass knuckles as well) and don't look back
Bananaclip is offline   Reply With Quote
Old 08-22-2018, 10:55 AM   #109
Plus 1 on that. For the price you can not go wrong. My truggy is close to 9lbs and I thrash it like a rock bouncer. These axles have held up great and will go on all my future builds.
Old 09-16-2018, 07:25 AM   #110
This is from a few packs. So smooth. No gouging
And I can confirm LURC .185 will clear SSD Brass knuckles!!!!!
Old 01-18-2019, 04:38 PM   #111
Hal
Just purchased a set to make a sportsman class 2.2. Was wondering about gears for these axles. I would like to do OD/UD gears to get better climbing and steering. Are there any gears available for these axles. I just started looking, not much out there. I only found one option. Any ideas. I may try to do it with a tranny if I have to.
Hal is offline   Reply With Quote
Old 05-16-2020, 09:24 AM   #112
Is the upper link mounts in these Diamond Pro axle case taller than the Axial AR44 axle housings?
Jabird is offline   Reply With Quote
Old 06-18-2020, 01:55 PM   #113
Is the bevel gear reversible?
Lou
TK421 is offline   Reply With Quote
New SSD Diamond Pro Axles - Similar Threads
Currie F9? Rockjocks? SSD Diamond Axles? 701scaler Axial SCX-10 24 04-02-2016 09:13 AM
