11-06-2017, 06:08 PM | #1 |
Newbie Join Date: Aug 2017 Location: Atlanta
| 4 link rear end- side to side slop
Recently I was running my 10.2 and noticed a lot of slop in the rear diff housing. It had to be something with the links. I got to looking and noticed it was the two upper links. A fella I was crawling with recommended I take a zip tie and tie it around the two rod ends on the diff housing side, I proceeded to do so and it’s solid as a rock. Does not put anything in a bind and works like a charm! Its a simple fix to carry out while crawling and while there is limited access to parts/tools. Hopefully new rod ends that aren’t so sloppy will be the more proper fix. Last edited by jksquires43; 11-06-2017 at 06:12 PM. Reason: Grammar/ more info |
11-07-2017, 04:16 AM | #2 |
Quarry Creeper Join Date: Aug 2015 Location: Worthington
| Re: 4 link rear end- side to side slop
So was the slop due to wear in the rod end/pivotball? I have noticed the stock plastic pivot balls wear quickly and cause slop, I replaced all the steering link balls with samix stainless steel ones and now have no slop in the steering.
4 link rear end- side to side slop - Similar Threads | ||||
Side to side rear axle play | powder4breakfast | Axial RR10 Bomber | 32 | 06-28-2016 12:47 AM |
RC4WD Lox & Crawler Tire Pictures Side By Side | stomper4x4.com | Losi Micro-Rock Crawler | 9 | 07-27-2010 07:34 PM |
4 link rear and cut down side plates | Flud unlimited | Axial AX-10 Scorpion | 4 | 10-27-2008 09:19 PM |
Traxxas Slash & Losi Desert Truck Side by Side | RPP Hobby | RPP Hobby | 26 | 06-24-2008 03:32 AM |
