11-16-2017, 03:16 PM | #1 |
Quarry Creeper Join Date: Dec 2016 Location: Toronto
| 10.2 length of links
Posted to newbie section about a week ago with no response. I have tried searching several times for measurements for the SCX10 ii front and rear links- eye to eye measurement. I have had no issue finding measurements for the OG SCX10, and I have been able to find the length of the actual rods for the ii as well. Since I will be making them myself and have several different sizes of rod ends to work with I need an actual eye to eye measurement for each link. I have never owned an axial truck before and have been separately purchasing parts to build an scx10ii chassis / axle / shock hoop D90 - All of the other parts will likely be a mix-match of whatever I can make fit or whatever I fabricate myself. Planning a forward mounted motor/trans and transfer case. I have the body, chassis rails, skid and crossbraces, as well as the xtra speed aluminum axle housings, most of the needed axle internals - and i would love to get started on assembly while I wait for the front scx10 ii shock hoops, ring and pinion gears, etc. that I ordered. Can anyone lend a hand? Want to build the links as stock, and then shorten the rears as necessary to fit the D90 wheelbase. Thanks in advance, Dustin Sent from my SGH-I747M using Tapatalk |
11-16-2017, 03:24 PM | #2 |
Newbie Join Date: Jan 2010 Location: auburn
| Re: 10.2 length of links
scx10.2 12.3" wheelbase uppers ETE: front 105mm rear 127mm lower ETE: front 114mm rear 135.5mm |
11-16-2017, 05:14 PM | #3 |
| Re: 10.2 length of links |
12-12-2018, 04:18 PM | #4 |
Newbie Join Date: Sep 2018 Location: Germany
The kit and RTR use a different style of links, but are these the same length?
12-12-2018, 09:55 PM | #5 |
Quarry Creeper Join Date: Jun 2008 Location: Central KY
12-12-2018, 10:15 PM | #6 |
12-13-2018, 08:37 AM | #7 |
12-15-2018, 04:43 PM | #8 | |
Newbie Join Date: Oct 2010 Location: SoIL
| Re: 10.2 length of links Quote:
edit: so far all have been about 2mm longer. surely they would not have made separate links for just the honcho for 2-3mm. idk. Last edited by Jon Boy; 12-17-2018 at 04:15 PM. | |
10.2 length of links - Similar Threads | ||||
Links length | Roesso | Tamiya Clod Buster | 5 | 09-24-2017 02:29 PM |
Length for wraith lower links and twin hammer links | Rckhrse | General Scale Talk | 0 | 08-22-2013 03:53 PM |
Length of the Links | jokerc72 | Axial Wraith | 0 | 07-08-2011 12:49 AM |
What length links for your BJ | Trimmy | Axial AX-10 Scorpion | 2 | 03-10-2008 11:33 PM |
Links- length and how many is necessary ?s | Tig | General Crawlers | 4 | 05-26-2007 12:15 PM |
