11-18-2017, 04:12 AM | #1 |
Newbie Join Date: May 2017 Location: UK
| LC70 Questions
I have wanted to get the LC70 body for a while now but does it fit on the SCX10 II chassis without modification. I know the rear suspension will need altering but is that all? Thanks |
11-18-2017, 05:01 AM | #2 |
Quarry Creeper Join Date: Feb 2009 Location: Houston
| Re: LC70 Questions
There is a mounting kit for the SCX10 ii & the LC70. It is flimsy & sets the body way up high. To get the body down, so the floor of the bed sits on the chassis rails (or close enough) you either: A: Figure a way to lose the rear shock towers (the front works just fine & the flimsiness of the body mount is minimized) & mount the shocks to the bed. B: Get a cantilever kit. C: Cut a hole in the bed to clear the rear shocks & shock towers. |
11-18-2017, 05:14 AM | #3 |
| Re: LC70 Questions
Thanks txbart I have seen the cantilever kit and it looks good so that's the way I would go. I have read somewhere that the LC70 Body wont fit the stock scx10 II chassis without modifying the motor. Does anyone know anything about this please. Thanks |
11-18-2017, 05:29 AM | #4 |
| Re: LC70 Questions
Depending on which version you have, kit or RTR the motor & transmission sits right in the middle of the cab/bed area to varying degrees. So you might have to do some cutting of the bed to accommodate the transmission. Give me a few hours & I can give you a more positive answer by comparing my Scx10 ii & LC70.
11-18-2017, 07:28 AM | #5 |
| Re: LC70 Questions
Ok Thank you.
11-18-2017, 08:04 AM | #6 |
| Re: LC70 Questions
Here are some pics, My SCX10ii is a kit with the old style trans setup, like in the RTR. With the front wheel in the front wheel well & the body resting on the side plates, everything stays well within the cab. I don’t believe there would be much need to alter the body if you were to do alterations to the chassis. Good luck! Sent from my iPad using Tapatalk |
11-18-2017, 09:17 AM | #7 |
| Re: LC70 Questions
Thanks txbart the pictures are great. I have read that there is a way to reverse the transmission that means the chassis stays the same but I have searched YouTube and I can't find anyone who has posted how to do it. Thank you. |
11-18-2017, 10:19 AM | #8 |
Newbie Join Date: Aug 2017 Location: loco hills
| Re: LC70 Questions
Bowhouse makes a mount that lets you flip the motor/trans around... GCM racing has a video of one on a scx10, you can get the part from shapeways
11-18-2017, 05:20 PM | #9 |
| Re: LC70 Questions
Thanks crazy ores I'll check it out.
11-20-2017, 09:18 AM | #10 |
Newbie Join Date: May 2017 Location: Brighton
| Re: LC70 Questions
This is what I did for my buddys build got the servo mount from circle city
11-20-2017, 09:20 AM | #11 |
| Re: LC70 Questions
Also made custom leaf spring mounts
11-21-2017, 04:04 AM | #12 |
| Re: LC70 Questions
That's very good crisdog80. I don't mind buying parts to fit to the truck but I'm not very good at making stuff from scratch. |
LC70 Questions - Similar Threads | ||||
My LC70 Build | Craggles123 | Axial SCX10 II | 24 | 10-23-2019 03:38 PM |
My LC70 build | Mello_Yello | 1.5 Scale Rigs | 11 | 01-09-2019 06:11 AM |
Ifs lc70 | wblteen | 1.9 Scale Rigs | 35 | 09-29-2017 07:07 PM |
Mercedes G & LC70 | ROB850R | Scale Videos! | 0 | 09-14-2017 02:17 PM |
