12-17-2017, 01:35 PM | #1 |
Rock Stacker Join Date: Dec 2017 Location: Greece
| 20c LiPo too low for AE-5 ESC?
Greetings. New member of the forums as well as new SCX10.2 RTR owner The only battery i own right now is a 2s 3250mah 20C and the truck seems to run perfectly with it. However i was told that a 20C lipo is too low for the AE-5 ESC and it could fry it in the future. Is that true?
12-17-2017, 01:51 PM | #2 |
| Re: 20c LiPo too low for AE-5 ESC?
No. 20c ratig is the amount of amps the battery can discharge at once. so your 3250 is goo for 64-65 amps, constant, and my crawleres bound up only pull 25- 30 amps, depending on the motor. if you are running a 35 turn motor or so you will have no problems. btw 3s is quite a bit more efficient. I run small 30 c flight packs 2200 mah, so 62 amps, with no problems. |
12-17-2017, 02:03 PM | #3 |
Yes i use the stock 35t motor and i'll probably continue to use it for some time. It's good to know there is no problem I was actually thinking about buying a new 2s lipo but a 4000 or 5000 mah but i'll think about the 3s as well.
12-17-2017, 08:51 PM | #4 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
Any risk running a 3s 20c 4000 mah venom on the stock setup? Worth the performance benefit over a 2s 25c 5000 mah venom?
12-17-2017, 08:58 PM | #5 |
Should run fine, and you will see a noticable increase in performance for sure
12-18-2017, 10:54 AM | #6 |
Rock Crawler Join Date: May 2014 Location: Cluj-Napoca,Romania
I am always using 45C rate discharge,on any setup.I had customers burning electronics with a 20C discharge rate
12-18-2017, 11:01 AM | #7 |
RCC Addict Join Date: Jul 2008 Location: San Diego
I have found that higher C rated batteries last longer for me. After I use them I stick them on the charger and put them in storage mode. I use 3 cell lipo's in most of my trucks.
12-18-2017, 11:06 AM | #8 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
Traulus, that wasn't because of 20C. A 5000mAh 20C pack is rated for more current than, say, a 1800mAh 50C pack. Makes sense that higher rated packs last longer, they're more expensive and made to tighter tolerances. |
12-18-2017, 11:07 AM | #9 |
| Re: 20c LiPo too low for AE-5 ESC? |
20c LiPo too low for AE-5 ESC? - Similar Threads | ||||
Venom 5000 20c 2s lipo? | RockBiter | Electronics | 7 | 03-17-2017 05:58 PM |
Diference between 20C our a 70C on a lipo | PSH72 | Electronics | 23 | 11-03-2014 03:01 AM |
2S 20C-30C Lipo question. | kwonchoba | Electronics | 20 | 12-07-2011 04:39 PM |
