Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Servo rub
Old 12-21-2017, 08:35 PM   #1
Gold Star Baby!
Topher Builds's Avatar
Default Servo rub
I put a savox sw 0231mg into the rig but Iím getting Servo rub on one of my front links. Hereís a video so I donít need to fumble over explaining it.
Any good fixes for this? Raise the Servo perhaps? I believe there may be hardware in the packaging to do this but Iím not sure if thatís the purpose.
https://youtu.be/xtmv5GbvPPo
Thanks in advance
Topher Builds is offline   Reply With Quote
Old 12-21-2017, 08:49 PM   #2
Default Re: Servo rub
Thanks in advance
Is your servo arm the same length as the stock plastic?
Sent from my SM-G930P using Tapatalk
Jeepkid is offline   Reply With Quote
Old 12-21-2017, 08:59 PM   #3
Gold Star Baby!
Looks to be about the same length. There are 3 different holes for mounting the arm of the horn though. Perhaps moving up to the middle will clear that up, I’ll give that a try and see how that affects the turn radius.
Old 12-21-2017, 09:29 PM   #4
Looks to be about the same length. There are 3 different holes for mounting the arm of the horn though. Perhaps moving up to the middle will clear that up, Iíll give that a try and see how that affects the turn radius.
That will reduce the throw. A little longer arm will require less servo rotation but reduce the torque.
Sent from my SM-N910P using Tapatalk
Shawns303 is offline   Reply With Quote
Old 12-22-2017, 03:57 PM   #5
I have used the same servo in mine and used some extra bits to space the servo up. Also bet that if you compress the passagerer side the panhard bar will hit your servo horn.
NitroDarwin is offline   Reply With Quote
Old 12-22-2017, 11:13 PM   #6
Gold Star Baby!
Which parts did you use? The little rubber squares with holes? My fiddling with the horn today didnít solve the issue so still looking for a fix.
Old 12-24-2017, 07:36 AM   #7
In the scx10II kit there was some extra plastic bits that I used to space the servo up(looked like washer with tapered outside edge)
Old 12-24-2017, 02:19 PM   #8
Gold Star Baby!
I was able to use some rubber pieces from the Servo hardware that effectively raised it up enough that I don’t get any rub. Hopefully it stays consistent after running.
Servo rub - Similar Threads
YR Knuckles rub darren509 Axial Wraith 38 09-14-2015 11:12 PM
Will my PB RB's rub? Jeep757 Tires and Wheels 11 05-30-2014 08:37 PM
Tire Rub. Help juttsvw RC4WD Trail Finder 2 22 05-03-2013 05:39 PM
Possible rub Issue? BrianP Losi Mini-Rock Crawler 0 11-05-2011 01:10 PM
rub wanttocrawl Newbie General 4 08-13-2008 05:21 AM
