Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: AE-5 Lipo Cut off Always Enabled?
Old 12-23-2017, 12:54 PM   #1
Default AE-5 Lipo Cut off Always Enabled?
Alright so today was the first time i took the truck outside. I enjoyed the hell out of it! My brand new Gens Ace 3500mah 2S went on for about 1.5 hour which i thought was too much for a battery of that capacity so i replaced it with my second battery seeing that the ESC would not cut it off. Is there a "secret" setting to enable lipo cut off or is it always enabled? Did i pull the battery out too soon?
westerlycarrot9 is offline   Reply With Quote
Old 12-23-2017, 12:55 PM   #2
Default Re: AE-5 Lipo Cut off Always Enabled?
These trucks will last all day on a charge tbh. 1.5 hours is pretty normal.
Sparktek is offline   Reply With Quote
Old 12-23-2017, 12:56 PM   #3
Originally Posted by Sparktek View Post
Move the jumper to the lipo setting as shown in the manual
Sent from my Nexus 6P using Tapatalk
It is in lipo mode. I haven't touched anything on the esc.
Old 12-23-2017, 01:16 PM   #4
Sounds fine to me. My truck on a 5000mah 3s can last 2.5 -5 hours depending on how I'm driving.
Are you from westerly ri?
Sent from my SAMSUNG-SM-G920A using Tapatalk
Evo93 is offline   Reply With Quote
Old 12-23-2017, 01:30 PM   #5
I see. That's insane though! I'm used to my previous truck which was a fast U4 style rock racer (FTX Outlaw Brushless). That thing took out my 3250mah 2s in about 45 minutes! Actually I am from Greece. I got the username from my Games For Windows Live account
Old 12-23-2017, 01:35 PM   #6
Sorry, I thought I was on the tech board for my other truck and that jumper is the bane of that truck's existence.
I get about 5 hours out of my 5000mah battery.
Old 12-23-2017, 07:31 PM   #7
I run 5000 mah packs in my trailfinder. I normally run 1.30 hour and swap packs. When I charge my packs, they normally take less than 2500mah when I recharge. I’m sure I could go much further, but that’s what I do.
coffeeaddict17 is offline   Reply With Quote
Old 12-23-2017, 08:35 PM   #8
Originally Posted by coffeeaddict17 View Post
I run 5000 mah packs in my trailfinder. I normally run 1.30 hour and swap packs. When I charge my packs, they normally take less than 2500mah when I recharge. Iím sure I could go much further, but thatís what I do.
Notice the packs lasting any longer or not? I've been having bad luck.
Old 12-24-2017, 08:06 AM   #9
There are pins and jumpers on the AE-5 that set it for NiMH or lipo, you can look at the AE5 or listen to the beeps when first turned on. The beeps will tell you what it's set as, one short beep then long beep is NiMH mode and for lipo it will beep 2 or 3 short ones for 2 or 3 cells followed by a long beep
NitroDarwin is offline   Reply With Quote
Old 12-24-2017, 08:18 AM   #10
Since the day i took it out of the box it's been in lipo mode ;) 2 short beeps and a long beep when i connect the battery ;)
AE-5 Lipo Cut off Always Enabled? - Similar Threads
Lipo cut off does???? realsickclown Axial Wraith 7 07-12-2013 06:53 AM
Lipo cut off Losi man Losi Mini-Rock Crawler 8 03-29-2010 02:39 AM
Enabled/Disabled 4 wheel steering. Is it possible Bernard3rd Electronics 7 01-07-2008 09:08 PM
