Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Gmade XD diaphragm front shocks
Old 01-22-2018, 05:24 PM   #1
Default Gmade XD diaphragm front shocks
My son purchased a set of gmade XD diaphragm shocks for the front of his scx10 II, when he installed them we noticed that the right side shock bottom hits the drag link.
Has anyone else used these shocks and what did you do to fix the problem with the drag link interference.
Thank you
Doug
DougL is offline   Reply With Quote
Old 01-22-2018, 07:12 PM   #2
Default Re: Gmade XD diaphragm front shocks
Post a photo of what your talking about and we can help you out
littledoins is offline   Reply With Quote
Old 01-22-2018, 08:51 PM   #3
I had these on one of my rigs. Two things I remember doing was swapping the lower eyelets out for the stock axial ones. Threads were the same size. The lower spring cup will fit loose but should clear the pan hard. The other thing I think I did was grind a flat spot on the spring perch but I canít remember off hand.
lilws6 is offline   Reply With Quote
Old 07-07-2020, 09:15 AM   #4
How did these shocks work out for you? The design looks good but there isn't a lot of info on them.
Lou
TK421 is offline   Reply With Quote
Old 07-07-2020, 11:54 AM   #5
I ran these on an SCX10.2 a while back and I think I just used the link mount hole which should move the spring perch back and out of the way of the drag link. Though its possible I adjusted the caster a bit too.
Lou
The shocks are very nice but the available springs are on the stiff side so I cant really recommend them for crawlers.
HumboldtEF is offline   Reply With Quote
Gmade XD diaphragm front shocks - Similar Threads
Gmade 85mm diaphragm shocks SkiSteve Vaterra Twin Hammers 1 05-13-2017 04:16 PM
G-Made Diaphragm Shocks Help VTHDAN4467 Vaterra Twin Hammers 5 01-13-2016 02:30 PM
Gmade diaphragm shocks? Beej Vaterra Twin Hammers 4 03-20-2014 12:25 PM
Gmade diaphragm shock ? Manfjourde General Crawlers 4 06-04-2013 02:11 PM
