06-01-2018, 08:47 AM | #41 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
| Re: f-350 scx10ii build (picture heavy)
I didn't get a chance to post any comparison pics last evening. I did find time to look through some stuff and I failed to locate a 350 cab. I did find a bed side though. I am an old guy (41) and had to do yard work at the house instead of play...
06-02-2018, 09:43 PM | #42 |
Rock Crawler Join Date: Dec 2010 Location: tracy
Thinking about mounting the bed and cab separately onto the chassis... Sent from my Moto Z (2) using Tapatalk |
06-09-2018, 10:20 PM | #43 |
Some progress today. . Mounted up the bed to chassis separate from cab. Took 2 trys..1st try, the bed wasn't centered over the axle. 2nd try was alot better.. brackets are L brackets from orchard supply. .. going to use a thin sheet of aluminum for the bed floor. Still got to cut out for fender wells. Dont know how im gonna make those yet. Also not sure if I want to go up on the bed or down on the cab to make body lines line up..still trying to figure out how to mount up cab. Maybe use the magnet method with some type of alignment dowl so its straight Everytime. Sent from my Moto Z (2) using Tapatalk Last edited by wcdfmt510; 06-14-2018 at 08:07 PM. |
06-09-2018, 10:52 PM | #44 |
Rock Crawler Join Date: Dec 2012 Location: Utah
Such a cool truck man excited to see it progress |
06-09-2018, 10:56 PM | #45 |
| Re: f-350 scx10ii build (picture heavy) Thanks. Even though this is my first time scratch building things and using styrene. Or anything on this level. Im pretty happy so far... So much i want to do. Really debating on getting a second chassis and welding them together..still a long way to go. Sent from my Moto Z (2) using Tapatalk |
06-15-2018, 04:21 PM | #46 |
Set a tire in the bed. Deciding if i want to make a mount instead of a tailgate. Think im gonna do a tailgate instead. Still no idea how im gonna mount the cab.. Sent from my Moto Z (2) using Tapatalk |
07-18-2018, 12:02 AM | #47 |
Been a while since ive done anything with this rig. Had to move, and new baby a couple weeks away. Slowly getting back to it. Looking into a Jewelers torch so I can fab my own spare tire carrier and sliders and whatever else that will work.. never brazed before and watched some videos... Is there anything else that is cheaper than the Harris safety silv stuff? They things I plan on making do not need to be indestructible. Basically just need to hold together. And what's good material to use besides brake line Sent from my Moto Z (2) using Tapatalk |
07-22-2018, 07:00 PM | #48 |
So since my son wants a scx10ii deadbolt I'm gonna tear down the trail honcho and Rob it of the drivetrain and put it in my f350. Sent from my Moto Z (2) using Tapatalk |
07-22-2018, 10:33 PM | #49 |
Did a little work tonight. Tore down the hon honcho axle internals and transmission. put into the f350. Stock rtr front drive shaft fit. Need about a 8in lock rear shaft. I have to relocate the rear bed mounts forward a slight bit. Cab is just sitting on the frame/sliders. Had to get a flex shot. Front tires clear pretty good. Just got to trim the rear portion of the fender and the bumper a little to clear lock to lock Sent from my Moto Z (2) using Tapatalk |
07-22-2018, 10:34 PM | #50 |
Side shot Sent from my Moto Z (2) using Tapatalk |
07-22-2018, 11:02 PM | #51 |
Newbie Join Date: Dec 2017 Location: Jim Thorpe
you can easily get the bed level w/ the cab if you put spacers under bed. That will clean the look nicely.
07-22-2018, 11:06 PM | #52 |
I know. I got to relocate to bed mounts. Didn't measure correctly. Bed has to go forward and up a little. Debating on trying some RC fuel tubing I have to act a spacers and a more scale 1;1 "rubber" type mounts. Sent from my Moto Z (2) using Tapatalk
07-24-2018, 10:42 PM | #53 |
A few more pics of the front links. Debating on. Changing them for actual links..that driveshaft angel tho. Sent from my Moto Z (2) using Tapatalk |
07-24-2018, 10:48 PM | #54 |
Removed the upper link mounts and Smoothed out the rear axle for a Lil more scale look @ssd Sent from my Moto Z (2) using Tapatalk |
07-25-2018, 08:05 PM | #55 |
To cut up the honcho frame for the rear 4in rear section or to just buy a eBay chassis and cut up($1 Sent from my Moto Z (2) using Tapatalk |
07-30-2018, 09:09 PM | #56 |
Tore down the honcho all the way to the frame rails and gonna weld up extensions on that frame. Using the square tubing cut in half... Sent from my Moto Z (2) using Tapatalk |
07-30-2018, 09:57 PM | #57 |
RCC Addict Join Date: Mar 2011 Location: easton
Man all this progress your making on this thing is killing me. It’s making me want to bring the f350 quad cab build I was doing back from the dead. Sent from my iPhone using Tapatalk |
07-30-2018, 10:07 PM | #58 | |
| Re: f-350 scx10ii build (picture heavy) Quote:
I just ordered a narrow arb style front bumper from loops RC. Next I will be ordering 2 rear arb bumpers from them. 2 because I made the bed square and it's a little wider than the stock width bumpers. Also after I get the bed all done try to figure out how I mount up a hitch receiver.. Will get more pics of the bed soon. It's 3 sheets of .030 styrene and a .040 sheet of steel as the bed floor. I still need to figure out and build wheel wells and tailgate,bumper and the taillights. As for the cab, debating on a roof rack with 4" vp rigid lightbar. Maybe a 2"vp rigid lightbar on the front bumper Don't know what lighting I will be using for headlights, turn signals, taillights and fogz. As for the chassis. Weld up the frame rails and extensions. Debating on leaving 4 link or going leafs in front.. need a rc4wd ultra scale 7-8" driveshaft (none in stock anywhere) RC4WD HELP I NEED 1! Maybe get some leaf spring blocks. It's sitting on the stock 90mm shocks now with 4.7 tall tires. Need to either lift it or smaller tires.. There's alot more I'm leaving out cuz I can't think right now Sent from my Moto Z (2) using Tapatalk Last edited by wcdfmt510; 07-30-2018 at 10:12 PM. | |
07-31-2018, 12:11 AM | #59 |
Quarry Creeper Join Date: Feb 2018 Location: Melbourne Australia
I have been using Allthread links for a while but with out a case/cover. After seeing your sexy links, I just ordered some brass tube. Thanks for the inspiration! you truck kicks some serious butt.
08-01-2018, 10:39 PM | #60 |
Thanks. Ya. I used to make links like this back in the day when I had a og scx10 Chevy truggy. I'll look for pics. Back then I just used aluminum tubing. I wanted to do brass tubing to be different.. the thing I found with the brass tubing is you need to apply a couple coats of clear coat to it so they stay shinny. I'll probably redo them. I saw some axial ss links on rpp for like $6@ pair. And slide some brass tubing over those.Sent from my Moto Z (2) using Tapatalk
f-350 scx10ii build (picture heavy) - Similar Threads | ||||
2012 Mazdaspeed 3 build *picture heavy* | RubikonKid | 1:1 Full Size Vehicles | 3 | 07-03-2014 09:02 PM |
Trail Monkeys: Norwegian Wraith build [picture heavy] | Trail Monkey | Axial Wraith | 31 | 10-27-2013 01:09 AM |
CP RC PROJECT - Picture Heavy Build Thread | clubconcepts | Large Scale Rigs | 17 | 05-17-2012 07:53 AM |
Fish tank stand build - picture heavy | jetboat | Chit Chat | 85 | 04-28-2012 07:54 PM |
Re-Do (PICTURE HEAVY!!!!) | VenomCreeper987 | Venom Creeper | 17 | 01-18-2012 02:22 PM |
