08-01-2018, 10:41 PM | #61 |
Rock Crawler Join Date: Dec 2010 Location: tracy
| Re: f-350 scx10ii build (picture heavy)
Really debating on a smaller tire and/or some leaf spring blocks and longer shocks up front Sent from my Moto Z (2) using Tapatalk |
08-02-2018, 10:35 PM | #62 |
My shop foreman welded up these steel extensions to a factory steel scx10ii chassis. Tore down the aftermarket aluminum chassis to swap everything over. Just need to drill a few holes and modify the chassis for the leaf spring hanger. After all done mock up then paint. The extensions are about 1-2mm narrowed. To help with shackles Sent from my Moto Z (2) using Tapatalk |
08-04-2018, 05:30 PM | #63 |
Thinking changing the front 4 link out for leaf springs. I have another pair of leafs the RC4WD hangers. Just need another pair of gcm perches Sent from my Moto Z (2) using Tapatalk |
08-05-2018, 08:59 PM | #64 |
Few pics I took tonight with the new chassis, remointed the bed to fit the cab with a better gap between cab and bed. modified the rear wheel opening in the front a bit.. still no idea how I'm gonna mount the back of the cab to the chassis. The front will be stock body post with velco or magnets Sent from my Moto Z (2) using Tapatalk |
08-07-2018, 10:16 AM | #65 |
Took some extra wildboar driveshaft parts from my bomber kit and made a rear shaft. Not pretty, nor is it permanent. Sent from my Moto Z (2) using Tapatalk |
08-07-2018, 11:27 AM | #66 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
Get some smaller tires brother..... You are doing a great job on this one. Keep it up and you will have one to be proud of...
08-07-2018, 11:28 AM | #67 |
| Re: f-350 scx10ii build (picture heavy) |
08-07-2018, 12:57 PM | #68 |
Need some ideas on how to fill lower portion and whatnot Sent from my Moto Z (2) using Tapatalk |
08-07-2018, 05:12 PM | #69 |
Made rear bumper bracket. And trying out this 1/4 brass tubing and m3 nylon lock nut I hammered inside. Pretty damn tight fit. Sent from my Moto Z (2) using Tapatalk |
08-12-2018, 07:52 PM | #70 |
Got the lenses installed and painted. Also grille is cut out to Sent from my Moto Z (2) using Tapatalk |
08-12-2018, 09:25 PM | #71 |
At this point I'm $450 into it Sent from my Moto Z (2) using Tapatalk |
08-15-2018, 02:46 PM | #72 |
RCC Addict Join Date: Mar 2011 Location: easton
Now you’ve done it.... I have a loops model body coming! Anyways sorry if you’ve mentioned this already, but how long of a wheel base does this have? Sent from my iPhone using Tapatalk |
08-15-2018, 08:29 PM | #73 | |
| Re: f-350 scx10ii build (picture heavy) Quote:
I ended up ordering the narrow arb style front bumper and 2 rear bumpers for the f350 from loops. Should be here in a couple weeks Sent from my Moto Z (2) using Tapatalk Last edited by wcdfmt510; 08-15-2018 at 08:32 PM. | |
08-16-2018, 04:18 AM | #74 |
Ok with the double cab body, mine should be 360mm, or a hair over 14.1 inches Sent from my iPhone using Tapatalk |
08-16-2018, 06:17 AM | #75 | |
Sent from my Moto Z (2) using Tapatalk | |
08-16-2018, 06:25 AM | #76 | |
Yea that’s what is posted on their website so hopefully it’s right. I’m probably going to do something similar, and hopefully have the cab portion easy to take off for battery changes. Sent from my iPhone using Tapatalk | |
08-16-2018, 06:27 AM | #77 | |
08-16-2018, 06:44 AM | #78 | |
That would be a good idea. I’m still debating on going to speed or using a wraith trans that I have laying around for 2wd/4wd. Sent from my iPhone using Tapatalk | |
08-21-2018, 09:34 PM | #79 |
Should i convert front to leaf springs? Sent from my Moto Z (2) using Tapatalk |
08-21-2018, 09:51 PM | #80 |
f-350 scx10ii build (picture heavy) - Similar Threads | ||||
2012 Mazdaspeed 3 build *picture heavy* | RubikonKid | 1:1 Full Size Vehicles | 3 | 07-03-2014 09:02 PM |
Trail Monkeys: Norwegian Wraith build [picture heavy] | Trail Monkey | Axial Wraith | 31 | 10-27-2013 01:09 AM |
CP RC PROJECT - Picture Heavy Build Thread | clubconcepts | Large Scale Rigs | 17 | 05-17-2012 07:53 AM |
Fish tank stand build - picture heavy | jetboat | Chit Chat | 85 | 04-28-2012 07:54 PM |
Re-Do (PICTURE HEAVY!!!!) | VenomCreeper987 | Venom Creeper | 17 | 01-18-2012 02:22 PM |
