02-18-2018, 01:16 PM | #1 |
Newbie Join Date: Feb 2016 Location: Batavia
| samix scx10 2 link kit
Does anyone else have these installed? I am having an issue with the lower front link and upper front link hitting each other and preventing/ limiting full flex. Samix's website has no info and some images they have doesn't even have the front upper link installed... full extension max compression. About half the compression as passenger side Last edited by Ctremblay66; 02-18-2018 at 01:58 PM. |
02-18-2018, 02:51 PM | #2 |
Quarry Creeper Join Date: Feb 2009 Location: Houston
| Re: samix scx10 2 link kit
Maybe try turning them around so the bend is closer to the skid, then turn the rod so instead of an up/down bend they do an out/in bend?
02-18-2018, 03:30 PM | #3 |
Rock Crawler Join Date: Oct 2009 Location: Danish badlands
If you look at Samixes page it look like they are mounted the right way, with the short side of the bend towards the axle. https://www.rcsamix.com/index.php/fo...ring-link.html |
02-18-2018, 04:36 PM | #4 |
Quarry Creeper Join Date: Apr 2010 Location: Baraboo
I put the short side to the middle & long to the Axel...
02-22-2018, 09:18 AM | #5 |
Newbie Join Date: Jan 2010 Location: auburn
if im seeing things correctly it looks as though you are running a high clearance skid? i ran a vader high clearance skid on mine with the incision link set, which are not bent, and my upper and lower links were fighting for space as well. so the fact that you are running the samix bent links will only add to the interference issue. if you cant run it like that you will have to swap out the links to get a little more clearance or go back to a stock skid. hope that helps! |
02-22-2018, 02:04 PM | #6 |
Rock Crawler Join Date: May 2014 Location: Cluj-Napoca,Romania
Did you had plastic links?
02-22-2018, 02:18 PM | #7 |
They look to be thick. Thick links do often hit each other at some point in the suspension travel.
02-25-2018, 01:48 PM | #8 | |
| Re: samix scx10 2 link kit Quote:
02-25-2018, 02:52 PM | #9 |
Quarry Creeper Join Date: Jun 2012 Location: Washougal
I just played with the bends, rotating them till they fit. I have a flat skid also
samix scx10 2 link kit - Similar Threads | ||||
scx10 kit 4 link set up | jettrooper02 | Axial SCX-10 | 6 | 12-28-2010 06:05 PM |
