03-12-2018, 11:38 AM | #1 |
Newbie Join Date: Jan 2018 Location: Belgium
| Problem with rear differential
Hi all, I've start a build of a SCX10-2 Cherokee, now whem I have finished the build of the axles,I noticed a little problem, when You turn the wheels the differential will lock in one direction and not in the other... However when You turn on the pinion gear shaft everything works just fine... Is this normal...? The front diff seems not to have this problem... |
03-12-2018, 11:40 AM | #2 |
Rock Crawler Join Date: Oct 2009 Location: Danish badlands
| Re: Problem with rear differential
The diff work better with the gearbox and axles connected, its a problem many of us ran into building our SCX 10 II rides.
03-12-2018, 11:45 AM | #3 |
So You suggest to carry on with the build then? I just hope I dont break the whole thing at the first go... Kinda new to these things... |
03-12-2018, 12:01 PM | #4 |
I am sure if you pull in the input shaft as you turn it you will find it rotate smooth, on the other hand if you push a little on it while turning it will rotate bad. maybe put something thru the hole in the input shaft and give it a good pull, the bearings and so on might not be seated 100 % |
03-12-2018, 12:25 PM | #5 |
Quarry Creeper Join Date: Dec 2014 Location: Tulsa
Attach the rear WB8 HD driveshaft and try spinning it again. everything should be smooth. it seems the driveshaft holds the pinion from binding with the ring gear.
03-12-2018, 01:05 PM | #6 |
Exactly, if I spin the input shaft where the WB8 driveshaft will be connected it spins OK in both directions... I'll continue the build and see what happens when finished... |
03-16-2018, 09:19 PM | #7 |
Rock Stacker Join Date: Feb 2008 Location: Shingle Springs, CA
Tovanni - When I built mine earlier this year, I experienced the exact same thing. Everyone assured me this was normal, so I continued on. Once I got to the step where I attached the drive shafts, I learned that the way they connect to the pinion shaft actually pulls them a little, and eliminates the binding that you're seeing now. Keep on goin! You will be pleasantly surprised. |
03-17-2018, 04:13 PM | #8 | |
| Re: Problem with rear differential Quote:
That is the exact same answer that I got from Axial. I contacted them because I had one shockshaft with no thread on and a broken gear in my kit... I went to their HQ here in Belgium for the replacement parts and they explained to me why this problem excists... Great service there and friendly people! I will attach the axles tomorrow,and then see if everything is OK but I'm pretty sure it will... Verstuurd vanaf mijn SM-J730F met Tapatalk Last edited by Tovanni; 03-18-2018 at 04:01 PM. | |
03-18-2018, 04:06 PM | #9 | |
Verstuurd vanaf mijn SM-J730F met Tapatalk | |
Problem with rear differential - Similar Threads | ||||
Rear differential death | greengoblin | Axial Yeti | 38 | 10-13-2015 09:43 PM |
Rear differential issues? | Kanine38 | Axial AX-10 Scorpion | 18 | 05-18-2010 05:48 PM |
Underdrive in the rear differential | Kanine38 | Axial AX-10 Scorpion | 41 | 04-05-2010 06:36 AM |
Differential Hardware Problem | Tommy R | Losi Mini-Rock Crawler | 7 | 12-06-2008 02:11 AM |
