Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Weird suspension issue - droopy driver side
Old 03-16-2018, 05:45 PM   #1
Default Weird suspension issue - droopy driver side
Hi all!
I have been having a really weird issue with my SCX10 II for a while, and have all but given up hope. I can't figure out what is causing this to save my life! The driver side front of the truck sits significantly lower than the other side. I can pick up the truck and it will be close to level when I set it back down, but if there is any compression it reverts back to being lopsided. It doesn't seem to affect the crawling ability, nor the alignment. It just looks dorky.
I have gone thru all of the links to make sure they are the right length. I have also made sure none of them are binding. The shocks are buttery smooth and move freely as needed. I have moved the trailing link from one side to the other, but that didn't help. Verified the pitch on the knuckles are consistent with each other.
I'm at a complete loss as to what is causing this. I'd like to think that I'm intelligent enough to be able to figure it out, but it's painfully apparent that I'm not. heh
Some pix here if you're interested - I can take more if needed. https://imgur.com/a/xMiLj
Thanks in advance - hoping that another set of eyes will be able to help me figure out where I went wrong!
-Moddy
Here is what I'm running:
SCX10 II kit
Xtra Speed axle housings
Hot Racing aluminum knuckles and carriers
Traxxas big bore shocks with Axial springs
Boom Racing aluminum shock hoops
Chinese knock-off beadlocks w/ BFG AT KO2's
Devil HD Trans and Xfer case gears
eBay carbon fiber battery tray
eBay aluminum servo relocation mount
RC4WD Bumper w/ eBay Chinese shackles
Weise 20kg Servo
35T RC4WD motor
Hobbywing 1080 ESC
FlySky GT3C & receiver
The Modfather is offline   Reply With Quote
Old 03-16-2018, 06:34 PM   #2
Default Re: Weird suspension issue - droopy driver side
Move the shock spring combination to another wheel and see if the droop follows. Rule out a weak spring.
WildBill_NJ is offline   Reply With Quote
Old 03-16-2018, 06:35 PM   #3
Ahh - should have put that in my main post. Did that as well. I even put a stiffer spring up there - it helped, but I imagine it would throw the geometry outta whack...
Old 03-16-2018, 06:55 PM   #4
That’s odd. What’s the spring rates and oil weights?
When you compress the suspension evenly and let it level back out, how does the truck sit?
cinnabun is offline   Reply With Quote
Old 03-16-2018, 07:49 PM   #5
It has to be either the shock or the spring....you moved the spring but did you try swapping the shock to the passengers side...that's not a slight lean you think the tire was flat lol
Did you try putting a stock shock and spring in there for a shits and giggles?
Another thought those shock tower mounts are they identical...I know you have them both mounted in the same rearward hole but is the distance from frame to hole the same on both sides?
FANATICRC is offline   Reply With Quote
Old 03-16-2018, 08:38 PM   #6
Spring rates: 1.43 rear. 1.04 front. Oil is 30w.
If I set it down gently (so it's level) and compress it, it comes up lopsided.
Old 03-16-2018, 08:44 PM   #7
LOL! I know!!! When it compresses like in the pic, and I"m trailing, I can throttle up a bit and it recovers a little.
No, I didn't even build the stockers. I have moved the rears to the front tho. even with the heavier spring it exhibits the same behavior.
Huh - that's a good question - I will measure it up and take a look.
Old 03-17-2018, 05:27 AM   #8
Putting the 2 front shocks together and installing them would either rule out shock and spring or point to the mount
Old 03-17-2018, 07:32 AM   #9
I have the same thing going on as well, i am running traxxas trx4 shocks and springs, had it with my stock shocks (honcho rtr), so far i have assumed it is a side to side weight distribution issue with the radio and esc side being droopy, and the front shock droops more with the extra servo/battery weight up front, the only thing i have done is adjusted spring preload in that corner to compensate.
prondzy is offline   Reply With Quote
Old 03-17-2018, 11:38 AM   #10
Try putting some spacers / washers on the Pan Hard Bar.
My truck Leaned to one side after I put longer shocks on.
After installing the washers it was fine.
Stomper Fan 777 is offline   Reply With Quote
Old 03-17-2018, 11:40 AM   #11
I will try this today! This didn't even cross my mind.
Sent from my SM-G935V using Tapatalk
Old 04-08-2018, 10:35 AM   #12
Have you figured out what’s causing the left front shock to bind?
I’m going with the shock body is resting too close to the shock hoop, and when you compress th right front shock the angle of the axle is forcing your left shock against the left front shock hoop, causing you shock to bend internally, and making it bind against itself.
I would try a small spacer between the shock, and the shock hoop. I’m using proline powerstroke shocks (slash fronts), and I used 2mm spacers between my shocks, and hoops to pull the shocks away from the chassis, now the suspension compression is like you say “buttery smooth”.
Alexander_0_1 is offline   Reply With Quote
Weird suspension issue - droopy driver side - Similar Threads
Weird Servo Issue Ryanf58 Newbie General 8 06-04-2017 09:24 PM
Weird Servo Issue robertjpjr Electronics 7 02-05-2014 12:22 AM
weird controler issue puddin Axial Wraith 0 03-10-2013 11:25 AM
Weird servo issue Nimyad Electronics 23 02-13-2013 10:05 AM
Weird issue with new HH brxl LDogg Electronics 11 09-08-2011 08:02 PM
