06-13-2018, 06:52 AM | #21 |
Quarry Creeper Join Date: Mar 2007 Location: winchester
| Re: overdrive transfer case |
08-01-2018, 06:23 AM | #22 |
Summer has been busy to say the least. I still havnt taken the time to tear down the transmission to take pics and do a write up, probably be a good winter project The next comp is right around the corner and the overdrive mod is holding up great. To each his own and I put enough specs here that someone could remake the shaft and do this mod themselves. any questions just ask. Ill be running class 1 for the first time at the next comp. ill be running 1 rig for all three classes with only a body and tire swap and yes I run 1.9 with 4.75 hyrax in class 3. |
08-01-2018, 07:43 AM | #23 |
RCC Addict Join Date: Sep 2015 Location: Southern Maine
I’m not even an axial guy but I love what you’ve done here. Great idea with the shaft, but equally I like the motor flip with spacers making a forward motor set up. Very nice work indeed. GCM guys beware lol. Ben |
08-01-2018, 07:47 AM | #24 |
08-01-2018, 10:55 AM | #25 | |
| Re: overdrive transfer case Quote:
X2 | |
08-01-2018, 12:41 PM | #26 |
Rock Stacker Join Date: Jun 2018 Location: belgium
Maybe a stupid question but is not having a dustcover over the spur and slipper clutch cause any problems? Newbie here I ask it because the stock kit comes with a cover and I dont like the fact that with the cover on I cannot change the slipper adgustment. |
08-01-2018, 12:55 PM | #27 | |
your slipper adjustment should be one of those things where you set it and forget it | |
08-01-2018, 02:51 PM | #28 |
Thanks. I suppose mude can enter through the dust cover too but a little rock not. I might also remove that cover then. I set the slipper clutch tight and 1.5 turns back but I am still building so cant test it yet |
overdrive transfer case - Similar Threads | ||||
Overdrive T case? | TrailDawg362 | General Crawlers | 14 | 01-30-2021 01:39 AM |
need help with what transfer case is in the cr-01? | bigred_21_honda | Newbie General | 0 | 01-01-2010 04:17 PM |
GIVEAWAY-Cold Case, CRT 1.5 Transfer Case | Crawln Coles | Scale Accessories | 215 | 02-02-2009 03:31 PM |
