Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: AE-5L ESC upgrade or no?
Old 05-16-2018, 10:32 PM   #41
Default Re: AE-5L ESC upgrade or no?
The biggest advantages of the Mamba X are adjustability, strong BEC, and capability. You can dial in your throttle curves, turn drag brake on and off, and do many other things. The Hobbywing 1080 is a bad ass little ESC, especially for the price, but it is not as good as an X.
If going brushless, I'd go with the X NOT the micro. I know people say they run the micros with no issues but I have not been so lucky. I have ran 2 different Mamba Micro Xs on two different rigs with 2 different motors. One failed about 10 minutes into EASY driving and the other gets stupid hot fast. The first was on a lightweight truck with a 2300kv Roc 412. The second one was with a Slate 2280 on my Toyzuki V2 so it has overdrive, but weighs a good bit less than 8lbs. The truck was geared at 56/9 and the motor barely got warm. I switched back to a HH motor and 1080 esc and finished out the comp season with no issues.
Col_Sanders is offline   Reply With Quote
Old 05-17-2018, 08:07 AM   #42
I had the exact opposite experience.
My GCM Skeleton is super cramped for electronics so I was running a Tekin RS Gen 2 with a 2200kv Puller Pro stubby on 3S, after about 45 minutes it would constantly go into thermal shutdown. Replaced the Tekin with a Micro X because it was practically the only other ESC that would fit and all the ESC heat problems went away.
I will agree that if space or weight isn't a concern, I would definitely pick the Mamba X over the Micro X.
svt923 is offline   Reply With Quote
Old 05-17-2018, 08:22 AM   #43
Moderator
JatoTheRipper's Avatar
I'm surprised to hear that about Tekin. I've never had any of their ESCs heat up on me.
Old 05-17-2018, 09:04 AM   #44
The ESC must not have liked the cramped conditions in that truck, it runs fine in my TF2.
Old 05-17-2018, 09:13 AM   #45
Moderator
Some Tekin ESCs, like the RS Gen II, are in an extremely cramped case without any provisions (at least that I know of) for cooling. It's a miracle they don't all overheat. Somehow they pull it off. Their electronics must be extremely efficient.
It'd be cool of JRH or Robert@Castle should give some input on this.
Old 05-17-2018, 08:57 PM   #46
Odd...I've got two other local guys that had the Micro Xs in crawlers and they would also constantly overheat too. This isn't crawling in the summer...I had these in the fall/winter/spring, which is normally <70 degrees and the ESC had adequate room around it and above it.
Old 05-17-2018, 09:11 PM   #47
Maybe its related to humidity?
Rekreant is offline   Reply With Quote
AE-5L ESC upgrade or no? - Similar Threads
Esc and motor upgrade Darrell Electronics 8 05-04-2018 11:31 AM
Looking to upgrade esc/motor gen7crawler Redcat Crawlers 28 01-13-2018 07:17 AM
Upgrade esc? Nalleywhacker Newbie General 3 01-24-2016 01:01 PM
ESC upgrade? JC TABOR Electronics 3 04-29-2015 09:36 PM
Honco ESC upgrade rc-aggie Axial SCX-10 1 11-10-2010 02:51 PM
