05-17-2018, 10:36 PM | #1 |
Rock Crawler Join Date: May 2018 Location: USA
| Trail Honcho Top Heavy
Any ideas on how to reduce or compensate for my honcho being top heavy? It seems to roll over very easily. I have pics of my truck and have some 3d printed stuff on it, but I dont think it would add weight up high as most of it is on the bed. What do yall do to stop from rolling over and going up semi steep to steep inclines?
05-17-2018, 11:33 PM | #2 | |
Pebble Pounder Join Date: Dec 2017 Location: Pinehurst
| Re: Trail Honcho Top Heavy
Ad weight down low. Heavy wheels, incision 1/4" stainless steel links, hardened steel drive shafts, beef tubes, exc. Quote:
05-18-2018, 10:40 AM | #3 |
ANY weight up high affects RCs. To prove this, just remove your body and try to climb something you normally can't make when the body is installed. You'll probably make it. You wouldn't think a light, Lexan body affects the vehicle but it does to a great extent. You can go old school and put lead weights in the wheels or go more modern and get knuckle weights. Beef Tubes are great, but I'm not sure they are made for the SCX10 II. |
05-18-2018, 11:18 AM | #4 |
Quarry Creeper Join Date: Dec 2010 Location: Hanford
I added vp Currie axles, beef tubes brass knuckles, and SSD wheels. Try getting your body as low as possible on your chassis.
05-18-2018, 12:07 PM | #5 |
| Re: Trail Honcho Top Heavy |
05-18-2018, 12:50 PM | #6 |
Quarry Creeper Join Date: Aug 2015 Location: Worthington
The scx10II beef tubes are different than OG scx10 as they replace splined end of the housing thus you can only buy new beeftube axles with tubes installed.
05-18-2018, 01:49 PM | #7 |
Ok thank you guys. I saw that Hot Racing sells brass weights that go on the axles and weigh about 140 grams. I plan to get brass knuckles eventually too. How much added weight is too much?
05-18-2018, 06:27 PM | #8 | |
| Re: Trail Honcho Top Heavy Quote:
Reality is heavy rigs look very realistic moving across terrain. The problem is the heavy rigs are hard on drivetrain parts, and if that weight is rotating, it is exponentially more so. Brass knuckles, beef tubes, and the like are not bad weight. Heavy wheels and weight up high hurt performance. | |
05-19-2018, 07:19 PM | #9 | |
05-19-2018, 07:45 PM | #10 |
Pebble Pounder Join Date: Oct 2015 Location: B.C.
I'd try stainless lower links and go from there.
05-19-2018, 10:33 PM | #11 | |
It dosn't destroy drivetrain parts, It is just harder on them. Do it. you won't be dissapointed. | |
05-19-2018, 10:35 PM | #12 |
05-20-2018, 07:21 PM | #13 |
I put 4 oz in the front and 3 in the back tires, modded my battery tray to hold my 10500mah 2s more forward. Now the truck crawls wonderfully and doesnt even turtle at around 75 degrees compared to say 50 before.
05-22-2018, 06:41 PM | #14 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
Installing weight in the tires is a cheap way to add weight but is not the best. It is harder on your drivetrain. That doesn't mean that stuff will immediately start falling apart, its just going to add a little more strain that non rotational weight or rotating weight that is at least closer to the center of the axle (Beef Patties). SSD makes a couple different axle housings that have steel tubes and a plastic center section. That will add a bit of weight in a good spot and they are reasonably priced. You would need to buy c hubs for your front axle though since the Honcho's are molded into the axle housing. SSD also has some nice brass knuckles. Don't get too crazy with adding weight. |
05-22-2018, 07:55 PM | #15 |
Have you tried lowering your ride height?
05-22-2018, 07:59 PM | #16 |
| Re: Trail Honcho Top Heavy Im all the way down in the back and took the front down as low as I can without hitting the body all the time. I took it out today and it performed a lot better with the wheel weight. Another thing I did is modified my battery tray so I could use my 2s 10500mah battery which is huge and heavy and it goes pretty far forward which helped as well. I have some brass knuckles and the disc break metal accessory on order for some lower down non rotational weight. The weight in the tires helped a lot as well. I think once I get the knuckles I should fair even better. I am thinking about buying the axial stainless steel links 2 at a time to help as well.
05-22-2018, 08:00 PM | #17 | |
05-22-2018, 08:14 PM | #18 | |
This is how much they really cost vs vanquish. Note knuckles are included on the SSD quote but not the Curries Sent from my SM-G930V using Tapatalk | |
05-22-2018, 09:55 PM | #19 |
05-22-2018, 09:59 PM | #20 | |
But yes, just the housings for the added weight... $50 or so. Great upgrade Sent from my SM-G930V using Tapatalk | |
Trail Honcho Top Heavy - Similar Threads | ||||
RC4WD Trail finder 2 Axial SCX10 Honcho Rusty Bug honcho wraith at Durian Loop Trail | boolean21 | Scale Videos! | 0 | 04-06-2014 09:08 AM |
RC4WD Trail finder 2 Axial SCX10 Honcho Rusty Bug honcho wraith at Durian Loop Trail | boolean21 | Scale Videos! | 0 | 03-24-2014 05:02 AM |
top heavy. what will help?? | stanmondz | General Scale Talk | 6 | 06-10-2012 05:42 PM |
cr-01 top heavy | Witz | Tamiya CR-01 | 7 | 10-14-2008 09:27 PM |
