Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Incision or SSD links kit?
Old 05-27-2018, 02:29 AM   #21
Default Re: Incision or SSD links kit?
ST Racing Concepts SCX10 II Hardened Steel links also a good choice, if you like more scale look.
Teng is offline   Reply With Quote
Old 05-28-2018, 01:27 PM   #22
Ive been waiting a month for the Incision kit to come back in stock; decided to utilize the RPP Memorial Day coupon and bought the SSD chassis and suspension link set. Looking forward to getting it. Ive got alot of play on the aluminum steering links from my Cherokee kit. Only have two packs through it!
Techno Duck is offline   Reply With Quote
Old 05-29-2018, 03:52 AM   #23
I got two of the links from axial and they had serious play until I took out the plastic balls from my stock links and then they were tight like a tiger. SSD links are due in today, hopefully they will fit tighter cause those plastic balls wont last that long.
Rekreant is offline   Reply With Quote
Old 05-29-2018, 06:58 AM   #24
The SSD rod ends are slightly wider. Should make for a good fit.
Bananaclip is offline   Reply With Quote
Old 05-29-2018, 07:21 AM   #25
Good to hear, maybe I wont need to use these revo rod ends afterall. Good thing Traxxas parts are so cheap lol.
Incision or SSD links kit? - Similar Threads
SSD C-Hub and Incision CVDís dpcardoza Axial RR10 Bomber 8 07-16-2021 05:18 PM
Anyone using the Incision SS links? Drm31078 Axial RR10 Bomber 92 05-01-2018 11:37 AM
Questions about incision links? raddad1975 Axial RR10 Bomber 2 08-27-2017 09:25 PM
Incision Steel links waqr Axial Wraith 1 12-30-2016 08:59 AM
vanquish incision chassis and links help? perry3182 Axial AX-10 Scorpion 4 01-21-2010 08:58 AM
